Παλύω να κτίσω το rtl8188eus για android x86-64. Κατέβασα τον kernel:
git clone https://android.googlesource.com/kernel/common.git
cd common
git checkout android14-6.1-2024-04_r11
Μετά εκτέλεσα
make menuconfig
make scripts
Και έκανα clone τον driver rtl8188eus :
git clone https://github.com/aircrack-ng/rtl8188eus.git
cd rtl8188eus
Εφόσον έβαλα το Android SDK:
export ANDROID_SDK_ROOT=/home/pcmagas/Android
export ANDROID_HOME=/home/pcmagas/Android
export PATH=$PATH:$ANDROID_SDK_ROOT/cmdline-tools/latest/bin
export PATH=$PATH:$ANDROID_SDK_ROOT/emulator
export NDK_HOME=$ANDROID_HOME/ndk/27.0.11902837
export PATH=$PATH:$NDK_HOME/toolchains/llvm/prebuilt/linux-x86_64/bin
sdkmanager "ndk;27.0.11902837"
Και το κτίζω
export ARCH=x86_64
export CROSS_COMPILE=x86_64-linux-android-
make -C /home/pcmagas/dlink-decompile/common M=/home/pcmagas/dlink-decompile/rtl8188eus CC=x86_64-linux-android25-clang KSRC=~/dlink-decompile/common KDIR=~/dlink-decompile/common modules
Αλλα παίρνω το error
make: Entering directory '/home/pcmagas/dlink-decompile/common'
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
You are using: Android (11889484, +pgo, +bolt, +lto, +mlgo, based on r522817) clang version 18.0.1 (https://android.googlesource.com/toolchain/llvm-project d8003a456d14a3deb8054cdaa529ffbf02d9b262)
make[1]: *** No rule to make target 'scripts/mod/modpost', needed by '/home/pcmagas/dlink-decompile/rtl8188eus/Module.symvers'. Stop.
make: *** [Makefile:2009: modpost] Error 2
make: Leaving directory '/home/pcmagas/dlink-decompile/common'
Και δεν έχω ιδέα πως να προχωρίσω
