sudo dmidecode
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 3.1.1 present.
Table at 0xAE5C1000.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: Insyde
Version: F.05
Release Date: 02/01/2019
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 16 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Japanese floppy for NEC 9800 1.2 MB is supported (int 13h)
Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 15.5
Firmware Revision: 51.13
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: HP
Product Name: HP Laptop 15-db1xxx
Version: Type1ProductConfigId
Serial Number: CND9100PF0
UUID: 3336b542-933c-e911-8bb6-b00cd1f0afbc
Wake-up Type: Power Switch
SKU Number: 6HU38EA#AB7
Family: 103C_5335KV HP Notebook
Handle 0x0002, DMI type 2, 17 bytes
Base Board Information
Manufacturer: HP
Product Name: 85EA
Version: 51.13
Serial Number: PHYYND2MYC0Q2V
Asset Tag: Type2 - Board Asset Tag
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Type2 - Board Chassis Location
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 24 bytes
Chassis Information
Manufacturer: HP
Type: Notebook
Lock: Not Present
Version: Chassis Version
Asset Tag: Chassis Asset Tag
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x0000010E
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
SKU Number: <BAD INDEX>
Handle 0x0004, DMI type 4, 48 bytes
Processor Information
Socket Designation: FP5
Type: Central Processor
Family: Zen
Manufacturer: Advanced Micro Devices, Inc.
ID: 81 0F 81 00 FF FB 8B 17
Signature: Family 23, Model 24, Stepping 1
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
Voltage: 1.2 V
External Clock: 100 MHz
Max Speed: 3700 MHz
Current Speed: 2100 MHz
Status: Populated, Enabled
Upgrade: None
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Serial Number: Unknown
Asset Tag: Unknown
Part Number: Unknown
Core Count: 4
Core Enabled: 4
Thread Count: 8
Characteristics:
64-bit capable
Multi-Core
Hardware Thread
Execute Protection
Enhanced Virtualization
Power/Performance Control
Handle 0x0005, DMI type 7, 27 bytes
Cache Information
Socket Designation: L1 - Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 384 kB
Maximum Size: 384 kB
Supported SRAM Types:
Pipeline Burst
Installed SRAM Type: Pipeline Burst
Speed: 1 ns
Error Correction Type: Multi-bit ECC
System Type: Unified
Associativity: 8-way Set-associative
Handle 0x0006, DMI type 7, 27 bytes
Cache Information
Socket Designation: L2 - Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 2048 kB
Maximum Size: 2048 kB
Pipeline Burst
Speed: 1 ns
Handle 0x0007, DMI type 7, 27 bytes
Cache Information
Socket Designation: L3 - Cache
Configuration: Enabled, Not Socketed, Level 3
Installed Size: 4096 kB
Maximum Size: 4096 kB
Pipeline Burst
Speed: 1 ns
Associativity: 16-way Set-associative
Handle 0x0008, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J2604/J2606
Internal Connector Type: None
External Reference Designator: Keyboard
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x0009, DMI type 8, 9 bytes
Internal Reference Designator: J2605
External Reference Designator: Touch pad
Port Type: Mouse Port
Handle 0x000A, DMI type 8, 9 bytes
Internal Reference Designator: J1500
External Reference Designator: USB
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: J1501
Port Type: USB
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: J1502
Port Type: USB
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: J1301
Port Type: USB
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: J1300
External Reference Designator: Network
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x000F, DMI type 8, 9 bytes
Internal Reference Designator: J1707
Internal Connector Type: SAS/SATA Plug Receptacle
External Reference Designator: Sata HDD
External Connector Type: None
Port Type: SATA
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: J1705
External Reference Designator: Sata ODD
Port Type: SATA
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: J1100
External Reference Designator: DP0
Port Type: Video Port
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: J1102
External Reference Designator: DP2
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: J2106
External Reference Designator: Microphone In
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: J2105
External Reference Designator: Head Phone
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: Ctrl0Port0
External Reference Designator: Primary HDD Bay*
External Connector Type: SAS/SATA Plug Receptacle
Port Type: SATA
Handle 0x0016, DMI type 8, 9 bytes
Internal Reference Designator: Ctrl0Port1
External Reference Designator: Secondary HDD Bay*
Port Type: SATA
Handle 0x0017, DMI type 9, 17 bytes
System Slot Information
Designation: J3600
Type: x1 PCI Express x1
Current Usage: Available
Length: Short
Characteristics:
3.3 V is provided
PME signal is supported
Hot-plug devices are supported
Bus Address: 0200:00:02.2
Handle 0x0018, DMI type 9, 17 bytes
Designation: J3700
Length: Short
Characteristics:
3.3 V is provided
Handle 0x0019, DMI type 9, 17 bytes
Designation: J3605
Type: x8 PCI Express x8
Length: Short
Characteristics:
3.3 V is provided
Handle 0x001A, DMI type 9, 17 bytes
Designation: J3702
Type: x1 Other
Length: Short
Characteristics:
3.3 V is provided
Bus Address: 0200:00:02.4
Handle 0x001B, DMI type 9, 17 bytes
Designation: J3703
Type: x1 Other
Length: Short
Characteristics:
3.3 V is provided
Bus Address: 0200:00:02.5
Handle 0x001C, DMI type 9, 17 bytes
Designation: J4000
Length: Short
Characteristics:
3.3 V is provided
Bus Address: 0200:00:02.6
Handle 0x001D, DMI type 11, 5 bytes
OEM Strings
String 1: $HP$
String 2: LOC#ABA
String 3: BCU_Y
String 4: ABS 70/71 78 79 7A 7B
String 5: OemString5
String 6: HP_Mute_LED_P_G
String 7: FBYTE#3K3Q6b7B7K7P7WaBapaqasawbCbhcbdUdpdqfP.Rq;
String 8: BUILDID#18WW2WYT602#SAB7#DAB7;
String 9: OemString9
String 10: OemString10
String 11: OemString11
Handle 0x001E, DMI type 12, 5 bytes
System Configuration Options
Option 1: ConfigOptions1
Option 2: ConfigOptions2
Option 3: ConfigOptions3
Option 4: ConfigOptions4
Option 5: ConfigOptions5
Option 6: ConfigOptions6
Option 7: ConfigOptions7
Option 8: ConfigOptions8
Handle 0x001F, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 5
en|US|iso8859-1,0
fr|FR|iso8859-1,0
es|ES|iso8859-1,0
zh|TW|unicode,0
zh|CN|unicode,0
Currently Installed Language: en|US|iso8859-1,0
Handle 0x0020, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 64 GB
Error Information Handle: 0x0023
Number Of Devices: 2
Handle 0x0021, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x0020
Error Information Handle: 0x0024
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Bottom-slot 1(left)
Bank Locator: P0 CHANNEL A
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 2667 MT/s
Manufacturer: Samsung
Serial Number: 94B5CF33
Asset Tag: Not Specified
Part Number: M471A5244CB0-CTD
Rank: 1
Configured Memory Speed: 2400 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
Handle 0x0022, DMI type 17, 40 bytes
Memory Device
Error Information Handle: No Error
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: SODIMM
Set: None
Locator: Bottom-slot 2(right)
Bank Locator: P0 CHANNEL B
Type: DDR
Type Detail: Unknown Synchronous
Speed: Unknown
Manufacturer: Unknown
Rank: Unknown
Configured Memory Speed: Unknown
Minimum Voltage: Unknown
Maximum Voltage: Unknown
Configured Voltage: Unknown
Handle 0x0023, DMI type 18, 23 bytes
32-bit Memory Error Information
Type: OK
Granularity: Unknown
Operation: Unknown
Vendor Syndrome: Unknown
Memory Array Address: Unknown
Device Address: Unknown
Resolution: Unknown
Handle 0x0024, DMI type 18, 23 bytes
Type: OK
Operation: Unknown
Resolution: Unknown
Handle 0x0025, DMI type 18, 23 bytes
Type: OK
Operation: Unknown
Resolution: Unknown
Handle 0x0026, DMI type 19, 31 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Array Handle: 0x0020
Partition Width: 1
Handle 0x0027, DMI type 20, 35 bytes
Memory Device Mapped Address
Range Size: 4 GB
Physical Device Handle: 0x0021
Memory Array Mapped Address Handle: 0x0026
Partition Row Position: 1
Handle 0x0028, DMI type 21, 7 bytes
Built-in Pointing Device
Type: Touch Pad
Interface: PS/2
Buttons: 4
Handle 0x0029, DMI type 22, 26 bytes
Portable Battery
Manufacturer: 333-42-5C-A
Manufacture Date: <null str
Serial Number: <null string>
Design Capacity: 41926 mWh
Design Voltage: 11550 mV
SBDS Version: 1
Maximum Error: 1%
SBDS Chemistry: LION
OEM-specific Information: 0x000A070C
Handle 0x002A, DMI type 26, 22 bytes
Voltage Probe
Description: Voltage Probe Description
Status: Unknown
Maximum Value: Unknown
Minimum Value: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
OEM-specific Information: 0x00000000
Nominal Value: Unknown
Handle 0x002B, DMI type 27, 15 bytes
Cooling Device
Temperature Probe Handle: 0x002C
Type: Fan
Status: OK
Nominal Speed: 8192 rpm
Description: Cooling Device Description
Handle 0x002C, DMI type 28, 24 bytes
Temperature Probe
Description: Temperature Probe Description
Status: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
OEM-specific Information: 0x00008000
Nominal Value: 0.0 deg C
Handle 0x002D, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x002E, DMI type 40, 18 bytes
Additional Information 1
Referenced Handle: 0x0018
Referenced Offset: 0x05
String: PCIExpressx16
Value: 0xaa
Additional Information 2
Referenced Handle: 0x0000
String: Compiler Version: VC 9.0
Value: 0x05dc
Handle 0x002F, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Broadcom 5762
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:03:00.0
Handle 0x0030, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Realtek ALC701
Type: Sound
Status: Enabled
Type Instance: 1
Bus Address: 00ff:ff:1f.7
Handle 0x0031, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Hanksville Gbe Lan Connection
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:02:00.0
Handle 0x0032, DMI type 41, 11 bytes
Onboard Device
Reference Designation: WLAN
Type: Other
Status: Enabled
Type Instance: 1
Handle 0x0033, DMI type 43, 31 bytes
TPM Device
Vendor ID: AMD
Specification Version: 2.0 Firmware Revision: 3.34
Description: TPM Device Characteristics:
TPM Device characteristics not supported
Handle 0xFEFF, DMI type 127, 4 bytes
End Of Table
sudo lshw
description: Notebook
product: HP Laptop 15-db1xxx (6HU38EA#AB7)
κατασκευαστής: HP
version: Type1ProductConfigId
serial: CND9100PF0
πλάτος: 64 bits
capabilities: smbios-3.1.1 dmi-3.1.1 smp vsyscall32
configuration: boot=normal chassis=notebook family=103C_5335KV HP Notebook sku=6HU38EA#AB7 uuid=42B53633-3C93-11E9-8BB6-B00CD1F0AFBC
*-core
description: Μητρική κάρτα
product: 85EA
κατασκευαστής: HP
physical id: 0
version: 51.13
serial: PHYYND2MYC0Q2V
υποδοχή: Type2 - Board Chassis Location
*-firmware
description: BIOS
κατασκευαστής: Insyde
physical id: 0
version: F.05
date: 02/01/2019
μέγεθος: 128KiB
χωρητικότητα: 16MiB
capabilities: pci upgrade shadowing cdboot bootselect edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acpi usb biosbootspecification uefi
*-cpu
description: Κεντρική μονάδα επεξεργασίας (CPU)
product: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
κατασκευαστής: Advanced Micro Devices [AMD]
physical id: 4
πληροφορίες διαύλου: cpu@0
version: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
serial: Unknown
υποδοχή: FP5
μέγεθος: 1442MHz
χωρητικότητα: 3700MHz
πλάτος: 64 bits
ρολόι: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp x86-64 constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_pstate sme ssbd sev ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 xsaves clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca cpufreq
configuration: cores=4 enabledcores=4 threads=8
*-cache:0
description: L1 cache
physical id: 5
υποδοχή: L1 - Cache
μέγεθος: 384KiB
χωρητικότητα: 384KiB
ρολόι: 1GHz (1.0ns)
capabilities: pipeline-burst internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 6
υποδοχή: L2 - Cache
μέγεθος: 2MiB
χωρητικότητα: 2MiB
ρολόι: 1GHz (1.0ns)
configuration: level=2
*-cache:2
description: L3 cache
physical id: 7
υποδοχή: L3 - Cache
μέγεθος: 4MiB
χωρητικότητα: 4MiB
ρολόι: 1GHz (1.0ns)
configuration: level=3
*-memory
description: Μνήμη συστήματος
physical id: 20
υποδοχή: Πλακέτα συστήματος ή μητρική πλακέτα
μέγεθος: 4GiB
*-bank:0
description: SODIMM DDR4 Synchronous Unbuffered (Unregistered) 2667 MHz (0,4 ns)
product: M471A5244CB0-CTD
κατασκευαστής: Samsung
physical id: 0
serial: 94B5CF33
υποδοχή: Bottom-slot 1(left)
μέγεθος: 4GiB
πλάτος: 64 bits
ρολόι: 2667MHz (0.4ns)
*-bank:1
description: SODIMM DDR Synchronous [empty]
product: Unknown
κατασκευαστής: Unknown
physical id: 1
serial: Unknown
υποδοχή: Bottom-slot 2(right)
*-pci:0
description: Host bridge
product: Raven/Raven2 Root Complex
κατασκευαστής: Advanced Micro Devices, Inc. [AMD]
physical id: 100
πληροφορίες διαύλου: pci@0000:00:00.0
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-generic UNCLAIMED
description: IOMMU
product: Raven/Raven2 IOMMU
physical id: 0.2
πληροφορίες διαύλου: pci@0000:00:00.2
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
capabilities: msi ht bus_master cap_list
configuration: latency=0
*-pci:0
description: PCI bridge
product: Raven/Raven2 PCIe GPP Bridge [6:0]
physical id: 1.1
πληροφορίες διαύλου: pci@0000:00:01.1
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
configuration: driver=pcieport
πόροι: irq:26 ioport:4000(size=4096) μνήμη:c0a00000-c0bfffff ioport:c0c00000(size=2097152)
*-pci:1
physical id: 1.2
πληροφορίες διαύλου: pci@0000:00:01.2
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
πόροι: irq:27 ioport:3000(size=4096) μνήμη:c0900000-c09fffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
κατασκευαστής: Realtek Semiconductor Co., Ltd.
physical id: 0
πληροφορίες διαύλου: pci@0000:02:00.0
λογικό όνομα: eno1
version: 15
serial: b0:0c:d1:f0:af:bc
χωρητικότητα: 1Gbit/s
πλάτος: 64 bits
ρολόι: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII
πόροι: irq:49 ioport:3000(size=256) μνήμη:c0904000-c0904fff μνήμη:c0900000-c0903fff
*-pci:2
physical id: 1.3
πληροφορίες διαύλου: pci@0000:00:01.3
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
πόροι: irq:28 ioport:2000(size=4096) μνήμη:c0800000-c08fffff
*-network
description: Ασύρματη διεπαφή
product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
physical id: 0
πληροφορίες διαύλου: pci@0000:03:00.0
λογικό όνομα: wlo1
version: 00
serial: 48:5f:99:91:16:15
πλάτος: 64 bits
ρολόι: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8821ce ip=192.168.2.7 latency=0 multicast=yes wireless=IEEE 802.11bgn
πόροι: irq:70 ioport:2000(size=256) μνήμη:c0800000-c080ffff
*-pci:3
physical id: 1.5
πληροφορίες διαύλου: pci@0000:00:01.5
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
πόροι: irq:29 μνήμη:c0700000-c07fffff
*-storage
description: Non-Volatile memory controller
product: WD Black 2018/PC SN520 NVMe SSD
κατασκευαστής: Sandisk Corp
physical id: 0
πληροφορίες διαύλου: pci@0000:04:00.0
version: 01
πλάτος: 64 bits
ρολόι: 33MHz
capabilities: storage pm msi msix pciexpress nvm_express bus_master cap_list
configuration: driver=nvme latency=0
πόροι: irq:51 μνήμη:c0700000-c0703fff
*-pci:4
product: Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
physical id: 8.1
πληροφορίες διαύλου: pci@0000:00:08.1
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
capabilities: pci pm pciexpress msi normal_decode bus_master cap_list
πόροι: irq:30 ioport:1000(size=4096) μνήμη:c0200000-c06fffff ioport:b0000000(size=270532608)
*-display
description: VGA compatible controller
product: Picasso
κατασκευαστής: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
πληροφορίες διαύλου: pci@0000:05:00.0
version: c2
πλάτος: 64 bits
ρολόι: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list
configuration: driver=amdgpu latency=0
πόροι: irq:75 μνήμη:b0000000-bfffffff μνήμη:c0000000-c01fffff ioport:1000(size=256) μνήμη:c0600000-c067ffff
*-multimedia:0
description: Audio device
product: Raven/Raven2/Fenghuang HDMI/DP Audio Controller
physical id: 0.1
πληροφορίες διαύλου: pci@0000:05:00.1
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
configuration: driver=snd_hda_intel latency=0
πόροι: irq:72 μνήμη:c06c8000-c06cbfff
*-generic:0 UNCLAIMED
description: Encryption controller
product: Family 17h (Models 10h-1fh) Platform Security Processor
physical id: 0.2
πληροφορίες διαύλου: pci@0000:05:00.2
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
capabilities: pm pciexpress msi msix cap_list
πόροι: μνήμη:c0500000-c05fffff μνήμη:c06ce000-c06cffff
*-usb:0
description: USB controller
product: Raven USB 3.1
physical id: 0.3
πληροφορίες διαύλου: pci@0000:05:00.3
version: 00
πλάτος: 64 bits
ρολόι: 33MHz
capabilities: pm pciexpress msi msix xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
πόροι: irq:31 μνήμη:c0400000-c04fffff
*-usbhost:0
product: xHCI Host Controller
κατασκευαστής: Linux 5.4.0-37-generic xhci-hcd
physical id: 0
πληροφορίες διαύλου: usb@1
λογικό όνομα: usb1
version: 5.04
capabilities: usb-2.00
configuration: driver=hub slots=4 speed=480Mbit/s
*-usbhost:1
physical id: 1
πληροφορίες διαύλου: usb@2
λογικό όνομα: usb2
version: 5.04
capabilities: usb-3.10
configuration: driver=hub slots=4 speed=10000Mbit/s
*-usb:1
physical id: 0.4
πληροφορίες διαύλου: pci@0000:05:00.4
version: 00
πλάτος: 64 bits
ρολόι: 33MHz
πόροι: irq:40 μνήμη:c0300000-c03fffff
*-usbhost:0
physical id: 0
πληροφορίες διαύλου: usb@3
λογικό όνομα: usb3
version: 5.04
configuration: driver=hub slots=2 speed=480Mbit/s
*-usb:0
description: Συσκευή μαζικής αποθήκευσης
product: ASM105X series
κατασκευαστής: Asmedia
physical id: 1
πληροφορίες διαύλου: usb@3:1
λογικό όνομα: scsi0
version: 1.00
serial: GTN02GTBXMXG
capabilities: usb-2.00 scsi emulated scsi-host
configuration: driver=usb-storage speed=480Mbit/s
*-cdrom
description: DVD writer
product: DVDRW DA8AESH
κατασκευαστής: hp
physical id: 0.0.0
πληροφορίες διαύλου: scsi@0:0.0.0
λογικό όνομα: /dev/cdrom
λογικό όνομα: /dev/cdrw
λογικό όνομα: /dev/dvd
λογικό όνομα: /dev/dvdrw
λογικό όνομα: /dev/sr0
version: XH6M
capabilities: removable audio cd-r cd-rw dvd dvd-r
configuration: status=nodisc
*-usb:1
description: USB hub
product: USB2.0 Hub
κατασκευαστής: Genesys Logic, Inc.
physical id: 2
πληροφορίες διαύλου: usb@3:2
version: 88.32
configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
*-usb:0
description: Video
product: HP TrueVision HD Camera
κατασκευαστής: SunplusIT Inc
physical id: 1
πληροφορίες διαύλου: usb@3:2.1
version: 0.05
capabilities: usb-2.01
configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
*-usb:1
description: Ασύρματη διεπαφή Bluetooth
product: Bluetooth Radio
physical id: 3
πληροφορίες διαύλου: usb@3:2.3
version: 1.10
serial: 00e04c000001
capabilities: bluetooth usb-1.10
configuration: driver=btusb maxpower=500mA speed=12Mbit/s
*-usbhost:1
physical id: 1
πληροφορίες διαύλου: usb@4
λογικό όνομα: usb4
version: 5.04
configuration: driver=hub slots=1 speed=10000Mbit/s
*-multimedia:1 UNCLAIMED
description: Multimedia controller
product: Raven/Raven2/FireFlight/Renoir Audio Processor
physical id: 0.5
πληροφορίες διαύλου: pci@0000:05:00.5
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
capabilities: pm pciexpress msi cap_list
πόροι: μνήμη:c0680000-c06bffff
*-multimedia:2
product: Family 17h (Models 10h-1fh) HD Audio Controller
physical id: 0.6
πληροφορίες διαύλου: pci@0000:05:00.6
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
πόροι: irq:74 μνήμη:c06c0000-c06c7fff
*-generic:1
description: Non-VGA unclassified device
product: Raven/Raven2/Renoir Non-Sensor Fusion Hub KMDF driver
physical id: 0.7
πληροφορίες διαύλου: pci@0000:05:00.7
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
configuration: driver=i2c_amd_mp2 latency=0
πόροι: irq:31 μνήμη:c0200000-c02fffff μνήμη:c06cc000-c06cdfff
*-serial
description: SMBus
product: FCH SMBus Controller
physical id: 14
πληροφορίες διαύλου: pci@0000:00:14.0
version: 61
πλάτος: 32 bits
ρολόι: 66MHz
configuration: driver=piix4_smbus latency=0
πόροι: irq:0
*-isa
description: ISA bridge
product: FCH LPC Bridge
physical id: 14.3
πληροφορίες διαύλου: pci@0000:00:14.3
version: 51
πλάτος: 32 bits
ρολόι: 66MHz
capabilities: isa bus_master
*-pci:1
product: Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
physical id: 101
πληροφορίες διαύλου: pci@0000:00:01.0
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pci:2
physical id: 102
πληροφορίες διαύλου: pci@0000:00:08.0
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pci:3
product: Raven/Raven2 Device 24: Function 0
physical id: 103
πληροφορίες διαύλου: pci@0000:00:18.0
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pci:4
product: Raven/Raven2 Device 24: Function 1
physical id: 104
πληροφορίες διαύλου: pci@0000:00:18.1
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pci:5
product: Raven/Raven2 Device 24: Function 2
physical id: 105
πληροφορίες διαύλου: pci@0000:00:18.2
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pci:6
product: Raven/Raven2 Device 24: Function 3
physical id: 106
πληροφορίες διαύλου: pci@0000:00:18.3
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
configuration: driver=k10temp
πόροι: irq:0
*-pci:7
product: Raven/Raven2 Device 24: Function 4
physical id: 107
πληροφορίες διαύλου: pci@0000:00:18.4
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pci:8
product: Raven/Raven2 Device 24: Function 5
physical id: 108
πληροφορίες διαύλου: pci@0000:00:18.5
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pci:9
product: Raven/Raven2 Device 24: Function 6
physical id: 109
πληροφορίες διαύλου: pci@0000:00:18.6
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pci:10
product: Raven/Raven2 Device 24: Function 7
physical id: 10a
πληροφορίες διαύλου: pci@0000:00:18.7
version: 00
πλάτος: 32 bits
ρολόι: 33MHz
*-pnp00:00
product: PnP device PNP0c02
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device PNP0b00
physical id: 2
capabilities: pnp
configuration: driver=rtc_cmos
*-pnp00:02
product: PnP device HPQ8001
physical id: 3
capabilities: pnp
configuration: driver=i8042 kbd
*-pnp00:03
product: PnP device SYN327b
physical id: 5
capabilities: pnp
configuration: driver=i8042 aux
*-pnp00:04
physical id: 6
capabilities: pnp
*-pnp00:05
product: PnP device PNP0c01
physical id: 7
capabilities: pnp
*-battery
product: HT03041
κατασκευαστής: 333-42-5C-A
physical id: 1
version: <null str
serial: <null string>
υποδοχή: Primary
χωρητικότητα: 41926mWh
configuration: voltage=11,6V
