Manjaro 64b, 5.8 kernel, i3-4150 , δυο δίσκοι σε καλή κατάσταση , θερμοκρασίες κανονικές.
Και παλιότερα είχα παρόμοια θέματα με ubuntu
Προχθές είχα μια και τώρα άλλη μια.
Τα λάθη από dsemg ψάχνοντας με όρους
emerg
alert
crit
err
warn
notice
info
debug
ERRORS
[ 0.028157] ACPI: IRQ0 used by ovdmesgerride.
[ 0.028158] ACPI: IRQ9 used by override.
[ 0.298731] RAS: Correctable Errors collector initialized.
[ 3.518980] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 3.980132] fbcon: Deferring console take-over
[ 0.102664] ACPI: Using IOAPIC for interrupt routing
[ 0.115361] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.115408] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.115453] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.115498] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.115543] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.115588] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.115633] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.115678] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.279290] fbcon: Deferring console take-over
WARNINGS
[ 3.331934] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20200528/utaddress-204)
[ 3.331942] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20200528/utaddress-204)
[ 3.331945] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[ 3.331949] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20200528/utaddress-204)
[ 3.331953] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200528/utaddress-204)
[ 3.331955] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[ 3.331959] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20200528/utaddress-204)
[ 3.331962] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200528/utaddress-204)
[ 3.331965] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[ 4.658298] random: 1 urandom warning(s) missed due to ratelimiting
DEBUG
[ 0.812165] ehci-pci 0000:00:1a.0: debug port 2
[ 0.832916] ehci-pci 0000:00:1d.0: debug port 2
[ 2.335328] systemd[1]: Mounting Kernel Debug File System...
[ 2.387970] systemd[1]: Mounted Kernel Debug File System.
Τι hardware εχεις φιλε μου?Μνημες- επεξεργαστη- μητρικη-τροφοδοτικο και αν εχεις κανει καποιο overclock σε επεξεργαστη- μνημες καλο θα ηταν να το ξερουμε.Επισης τσεκαρε πρωτα την σελιδα του κατασκευαστη της μητρικης αν εχει καποια καινουργια εκδοση για τα bios και δομιμασε να την βαλεις.
Αυτά που κοροϊδεύουμε κάνουμε … Παράληψη δική μου.
Bios update έχει να ενημερώσει η ASRock από το 2015
O επεξεργαστής είναι απείραχτος
Ένα μήνυμα λάθους μετά την ενημέρωση πριν λίγο.
WARNING: Possibly missing firmware for module: xhci_pci
και ίσως το παρακάτω να έχει κάποια ανάμιξη (κλειστοί οδηγοί εγκατεστημένοι από προεπιλογή )
Προτεινω να δοκιμασεις πρωτα με τους ανοιχτους οδηγους να δεις πως θα σε παει και αν συνεχισεις να εχεις προβλημα εγκατεστησε https://snapcraft.io/install/fwts/manjaro
που θα μας δωσει αναλυτικες πληροφοριες
Αυτό είναι το μοναδικό μενού που με μπερδεύει.Όπως εμφανίζεται στην παρακάτω φώτο εγώ καταλάβαινα ότι ΔΕΝ είναι ενεργοποιημένοι οι ανοιχτοί οδηγοί οπότε όταν ενεργοποιούσα τις επιλογές Installed νομίζοντας ότι εγκαθιστώ τους ανοιχτούς στην ουσία έκανα το αντίθετο !
Εδώ είναι ένα θέμα που είχα με τους οδηγούς.
Ήταν εξ ορισμού ενεργοποιημένοι οι κλειστοί οδηγοί (video-linux) και τώρα πιστεύω ότι τους απενεργοποίησα και έχω μόνο τους ανοιχτούς!
Λοιπόν συνεχίζω έτσι παρακολουθώ και αν έχω πάλι επανεκκινήσεις εγκαθιστώ τους fwts και βλέπουμε.
