οπως ειπα και πιο πανω με πιανεις αδιαβαστο…
περιμενε μηπως σε βοηθησει καποιος εμπειρος χρηστης.
δοκίμασε όλες τις παραπάνω εντολές με το sudo μπροστά μήπως έχεις και εσύ πρόβλημα με τα permissions. Δώσε πρώτα την εντολή αυτήν σε ένα τερματικό
sudo tail -f /var/log/syslog
μετά βάλε την κάρτα
μετά πήγαινε και εδώ
https://packages.ubuntu.com/xenial/all/rtl8812au-dkms/download
Περίληψη
Dec 31 16:19:11 rockingchairu-GA-MA770T-UD3P shutter.desktop[3517]: GdkPixbuf-LOG **: #011Dimensions: 16 x 16 at /usr/bin/shutter line 2891.
Dec 31 16:19:11 rockingchairu-GA-MA770T-UD3P shutter.desktop[3517]: GdkPixbuf-LOG **: #011Rowstride: 64, Length: 1048 at /usr/bin/shutter line 2891.
Dec 31 16:19:11 rockingchairu-GA-MA770T-UD3P shutter.desktop[3517]: GdkPixbuf-LOG **: #011Copy pixels == false at /usr/bin/shutter line 2891.
Dec 31 16:19:12 rockingchairu-GA-MA770T-UD3P dbus-daemon[1478]: [session uid=1000 pid=1478] Activating via systemd: service name=‘org.gnome.Terminal’ unit=‘gnome-terminal-server.service’ requested by ‘:1.116’ (uid=1000 pid=4854 comm="/usr/bin/gnome-terminal.real " label=“unconfined”)
Dec 31 16:19:12 rockingchairu-GA-MA770T-UD3P systemd[1449]: Starting GNOME Terminal Server…
Dec 31 16:19:12 rockingchairu-GA-MA770T-UD3P dbus-daemon[1478]: [session uid=1000 pid=1478] Successfully activated service ‘org.gnome.Terminal’
Dec 31 16:19:12 rockingchairu-GA-MA770T-UD3P systemd[1449]: Started GNOME Terminal Server.
Dec 31 16:19:17 rockingchairu-GA-MA770T-UD3P kernel: [ 7962.685775] usb 2-6: USB disconnect, device number 8
Dec 31 16:19:17 rockingchairu-GA-MA770T-UD3P upowerd[1092]: unhandled action ‘unbind’ on /sys/devices/pci0000:00/0000:00:13.2/usb2/2-6
Dec 31 16:19:22 rockingchairu-GA-MA770T-UD3P colord-sane: io/hpmud/pp.c 627: unable to read device-id ret=-1
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P kernel: [ 7974.505510] usb 2-6: new high-speed USB device number 9 using ehci-pci
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P kernel: [ 7974.662709] usb 2-6: New USB device found, idVendor=2357, idProduct=0120
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P kernel: [ 7974.662718] usb 2-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P kernel: [ 7974.662723] usb 2-6: Product: 802.11ac WLAN Adapter
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P kernel: [ 7974.662727] usb 2-6: Manufacturer: Realtek
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P kernel: [ 7974.662731] usb 2-6: SerialNumber: 00e04c000001
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P mtp-probe: checking bus 2, device 9: “/sys/devices/pci0000:00/0000:00:13.2/usb2/2-6”
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P mtp-probe: bus: 2, device: 9 was not an MTP device
Dec 31 16:19:29 rockingchairu-GA-MA770T-UD3P upowerd[1092]: unhandled action ‘bind’ on /sys/devices/pci0000:00/0000:00:13.2/usb2/2-6
Dec 31 16:19:34 rockingchairu-GA-MA770T-UD3P colord-sane: io/hpmud/pp.c 627: unable to read device-id ret=-1
Το δοκίμασα και αυτό, αλλά τη διαφορά να κάνει; Είναι ήδη εγκατεστημένος ο driver, αλλά δεν λέει να εμφανιστεί σωστά ο adapter. Επίσης, γιατί δεν βγάζει κάτι το rfkill;
Δες στο syslog αν σου λέει τίποτα για permissions
Το αποτέλεσμα της εντολής :
lsmod | grep rtl8812au
τι βγάζει, είναι φορτωμένο το module στον πυρήνα?
Αν όχι δοκίμασε έτσι :
sudo modprobe rtl8812au
lsmod
Περίληψη
rockingchairu@rockingchairu-GA-MA770T-UD3P:~$ lsmod
Module Size Used by
8812au 1331200 0
cfg80211 536576 1 8812au
rndis_host 16384 0
cdc_ether 16384 1 rndis_host
usbnet 36864 2 rndis_host,cdc_ether
wmi_bmof 16384 0
nvidia_drm 40960 2
nvidia_modeset 1044480 14 nvidia_drm
nvidia 13262848 552 nvidia_modeset
snd_hda_codec_hdmi 45056 1
joydev 20480 0
edac_mce_amd 28672 0
kvm 528384 0
snd_hda_codec_realtek 98304 1
irqbypass 16384 1 kvm
snd_hda_codec_generic 69632 1 snd_hda_codec_realtek
snd_hda_intel 36864 8
snd_hda_codec 114688 4 snd_hda_intel,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek
snd_seq_midi 16384 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_hda_core 69632 5 snd_hda_intel,snd_hda_codec,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek
snd_hwdep 16384 1 snd_hda_codec
input_leds 16384 0
snd_ctxfi 94208 4
serio_raw 16384 0
snd_rawmidi 28672 1 snd_seq_midi
snd_pcm 86016 5 snd_ctxfi,snd_hda_intel,snd_hda_codec,snd_hda_core,snd_hda_codec_hdmi
k10temp 16384 0
snd_seq 57344 2 snd_seq_midi_event,snd_seq_midi
drm_kms_helper 151552 1 nvidia_drm
snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi
drm 344064 5 nvidia_drm,drm_kms_helper
ipmi_devintf 16384 0
snd_timer 28672 2 snd_seq,snd_pcm
ipmi_msghandler 49152 2 nvidia,ipmi_devintf
mac_hid 16384 0
snd 69632 36 snd_ctxfi,snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_seq_device,snd_hda_codec_realtek,snd_pcm
fb_sys_fops 16384 1 drm_kms_helper
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
wmi 20480 1 wmi_bmof
soundcore 16384 1 snd
ati_agp 16384 0
shpchp 32768 0
sch_fq_codel 20480 3
parport_pc 32768 1
ppdev 20480 0
lp 20480 0
parport 45056 3 lp,parport_pc,ppdev
ip_tables 20480 0
x_tables 28672 1 ip_tables
autofs4 40960 2
pata_acpi 16384 0
uas 20480 0
usb_storage 57344 1 uas
hid_generic 16384 0
usbhid 49152 0
hid 98304 2 hid_generic,usbhid
firewire_ohci 36864 0
firewire_core 57344 1 firewire_ohci
crc_itu_t 16384 1 firewire_core
ahci 36864 2
r8169 81920 0
i2c_piix4 24576 0
libahci 32768 1 ahci
pata_atiixp 16384 0
mii 16384 2 r8169,usbnet
grep Και sudo modprobe rtl8812au απλά με πετάνε στην από κάτω γραμμή του terminal.
Δεν βλέπω κάτι.
'Εγραψα και στο forum της TP-Link μπας και βοηθήσει κάποιος από αυτούς!
