καλημερα,
εχω τα παρακάτω 2 εξωτερικά usb adapters
lsusb
Bus 002 Device 006: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 002 Device 003: ID 0bda:8172 Realtek Semiconductor Corp. RTL8191SU 802.11n WLAN Adapter
εχω, και με τα 2 πρόβλημα, να συνδεθώ σε wifi με το wpa_suplicant ενώ αντιθετα λειτουργούν με το netctl
οι ρυθμίσεις στο /etc/wpa_supplicant/wpa_supplicant-wlp0s20u2.conf
είναι
network={
ssid="...."
#psk="20363564"
#proto=WPA
key_mgmt=WPA-PSK
pairwise=CCMP
group=CCMP
priority=10
τρέχω το wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant-wlp0s20u2.conf -iwlp0s20u2
το πρόβλημα που υπάρχει :
sudo systemctl status wpa_supplicant@wlp0s20u2.service
Jan 24 08:55:49 arch systemd[1]: Started WPA supplicant daemon (interface-specific version).
Jan 24 08:55:49 arch wpa_supplicant[2780]: Successfully initialized wpa_supplicant
Jan 24 08:55:49 arch wpa_supplicant[2780]: nl80211: Could not configure driver mode
Jan 24 08:55:49 arch wpa_supplicant[2780]: nl80211: deinit ifname=wlp0s20u2 disabled_11b_rates=0
Jan 24 08:55:49 arch wpa_supplicant[2780]: wlp0s20u2: Failed to initialize driver interface
Jan 24 08:55:49 arch systemd[1]: wpa_supplicant@wlp0s20u2.service: Main process exited, code=exited, status=255/EXCEPTION
Jan 24 08:55:49 arch systemd[1]: wpa_supplicant@wlp0s20u2.service: Failed with result 'exit-code'.
τρέχοντας το
wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant-wlp0s20u2.conf -iwlp0s20u2 -Dwext
εχει αποτέλεσμα
rfkill: Cannot get wiphy information
wlp0s20u2: Trying to associate with 04:4f:4c:da:46:16 (SSID='....' freq=2412 MHz)
Failed to add supported operating classes IE
wlp0s20u2: Association request to the driver failed
wlp0s20u2: Associated with 04:4f:4c:da:46:16
wlp0s20u2: WPA: Key negotiation completed with 04:4f:4c:da:46:16 [PTK=CCMP GTK=CCMP]
wlp0s20u2: CTRL-EVENT-CONNECTED - Connection to 04:4f:4c:da:46:16 completed [id=0 id_str=]
δείχνει να εχει συνδεθεί (???) αλλά το ip a εχει αντίθετη αποψη
3: wlp0s20u2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:0d:81:ae:ff:f6 brd ff:ff:ff:ff:ff:ff
ενω το iwconfig
wlp0s20u2 IEEE 802.11bgn ESSID:"...." Nickname:"rtl_wifi"
Mode:Managed Frequency:2.412 GHz Access Point: 04:4F:4C:DA:46:16
Bit Rate:150 Mb/s Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality=100/100 Signal level=100/100 Noise level=0/100
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
κάτι παίζει με τον driver που φορτώνεται
εχω ψαξει αρκετά αλλά είτε δεν εχω βρεί λύση είτε η λύση είναι αρκετά παλαιά (χρονικά) και το link για το driver που αναφέρεται δεν είναι διαθέσιμο
κάθε βοήθεια καλοδεχούμενη
ευχαριστώ
jim
