καλησπερα, προκειται για τον παρακατω υπολογιστη
$ inxi -F
System:
Host: Souiters-HP-Pavilion-Desktop-590-p0xxx
Kernel: 4.15.0-65-generic x86_64 bits: 64 Desktop: Cinnamon 4.2.4
Distro: Linux Mint 19.2 Tina
Machine:
Type: Desktop System: HP product: HP Pavilion Desktop 590-p0xxx v: N/A
serial: <root required>
Mobo: HP model: 843B v: 00 serial: <root required> UEFI: AMI v: F.31
date: 05/27/2019
CPU:
Topology: 6-Core model: Intel Core i5-8400 bits: 64 type: MCP
L2 cache: 9216 KiB
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 802 2: 806
3: 811 4: 800 5: 800 6: 800
Graphics:
Device-1: Intel driver: i915 v: kernel
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2)
v: 4.5 Mesa 19.0.8
Audio:
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server: ALSA v: k4.15.0-65-generic
Network:
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ce
IF: wlp2s0 state: down mac: 0c:96:e6:08:2e:fb
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: f4:39:09:34:9b:b8
Drives:
Local Storage: total: 2.05 TiB used: 72.99 GiB (3.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 250GB
ID-2: /dev/sda vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
Partition:
ID-1: / size: 33.77 GiB used: 9.27 GiB (27.4%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /home size: 185.90 GiB used: 63.71 GiB (34.3%) fs: ext4
dev: /dev/nvme0n1p4
ID-3: swap-1 size: 7.90 GiB used: 768 KiB (0.0%) fs: swap
dev: /dev/nvme0n1p2
Sensors:
System Temperatures: cpu: 49.0 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Info:
Processes: 260 Uptime: 10h 43m Memory: 7.62 GiB used: 4.21 GiB (55.3%)
Shell: bash inxi: 3.0.32
εχω στην κατω μπαρα ανοιχτο τον Thunderbird και για να εμφανιστει το παραθυρο της εφαρμογης πρεπει να κανω κλικ πανω στο εικονιδιο δυο και τρεις φορες.
Τα ιδια οταν παω να πατησω την καρτελα Σελιδοδεικτες στον Firefox.
και αλλα τετοια κουλα…
το πρωτοκολλο με τα λαθη του Συστηματος ειναι αυτο
09:30:39 kernel: PKCS#7 signature not signed with a trusted key
09:30:38 pulseaudio: [pulseaudio] pid.c: Daemon already running.
09:30:35 kernel: PKCS#7 signature not signed with a trusted key
09:30:35 kernel: ACPI Error: Method parse/execution failed \_SB.WMID.WMAA, AE_AML_BUFFER_LIMIT (20170831/psparse-550)
09:30:35 kernel: ACPI Error: Method parse/execution failed \HWMC, AE_AML_BUFFER_LIMIT (20170831/psparse-550)
09:30:35 kernel: ACPI Error: Field [D128] at bit offset/length 128/1024 exceeds size of target Buffer (160 bits) (20170831/dsopcode-235)
09:30:35 kernel: Couldn't get size: 0x800000000000000e
09:30:35 kernel: MODSIGN: Couldn't get UEFI db list
09:30:35 kernel: ACPI Error: 1 table load failures, 9 successful (20170831/tbxfload-246)
τα Προσθετα του Συστηματος ειναι ολα ενημερωμενα.
Μια μπακαλιστικη λυση που σκεφτηκα να φτιαξω ενα νεο Χρηστη.
Ευχαριστω για οποιαδηποτε βοηθεια.
