Οπως αναγράφω και στο snapcraft forum μετακίνησα το /var/lib/snapd
στο /home/snapd
με το παρακάτω σετ εντολών:
sudo service snapd stop
sudo rsync -ravp /var/lib/snapd /home/snapd
sudo chmod --reference=/var/lib/snapd /home/snapd
sudo ln -s /home/snapd /var/lib/snapd
Δηλαδή το μετέφερα σε μια θέση με περισσότερο χώρο και μετά έκανα πάλι πίσω symlink στην αρχική του θέση. Όμως η εντολή sudo systemctl status snapd
δίνει το αποτέλεσμα:
● snapd.service - Snappy daemon
Loaded: loaded (/lib/systemd/system/snapd.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2020-02-01 14:51:52 EET; 25min ago
Main PID: 1178 (snapd)
Tasks: 18 (limit: 4915)
CGroup: /system.slice/snapd.service
└─1178 /usr/lib/snapd/snapd
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "lxd" at revision 11348: cannot find installed snap "lxd" at revision 11348: missing file /snap/lxd/11348/meta/snap.yaml
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "snapcraft" at revision 3970: cannot find installed snap "snapcraft" at revision 3970: missing file /snap/snapcraft/3970/meta/s
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "skype" at revision 112: cannot find installed snap "skype" at revision 112: missing file /snap/skype/112/meta/snap.yaml
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "kde-frameworks-5-core18-sdk" at revision 31: cannot find installed snap "kde-frameworks-5-core18-sdk" at revision 31: missing
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "brave" at revision 63: cannot find installed snap "brave" at revision 63: missing file /snap/brave/63/meta/snap.yaml
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "gnome-3-28-1804" at revision 116: cannot find installed snap "gnome-3-28-1804" at revision 116: missing file /snap/gnome-3-28-
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "core18" at revision 1668: cannot find installed snap "core18" at revision 1668: missing file /snap/core18/1668/meta/snap.yaml
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "gnome-characters" at revision 399: cannot find installed snap "gnome-characters" at revision 399: missing file /snap/gnome-cha
Φεβ 01 14:56:29 dimitris snapd[1178]: snapmgr.go:267: cannot read snap info of snap "minetest" at revision 1370: cannot find installed snap "minetest" at revision 1370: missing file /snap/minetest/1370/meta/snap
Φεβ 01 14:57:16 dimitris snapd[1178]: 2020/02/01 14:57:16 Unsolicited response received on idle HTTP channel starting with "HTTP/1.0 408 Request Time-out\r\nCache-Control: no-cache\r\nConnection: close\r\nConten
lines 1-18/18 (END)
Και δεν μπορεί να εκκινηθεί κανένα λογισμικό που εγκατέστησα μέσω snap. Έχετε ιδέα τις πταίει;
Η εντολή ls -l /home | grep snapd
δίνει το παρακάτω:
drwxr-xr-x 20 root root 4096 Φεβ 1 14:51 snapd
Ενώ η εντολη ls -l /var/lib/snapd
δίνει το παρακάτω αποτέλεσμα.
lrwxrwxrwx 1 root root 11 Φεβ 1 14:44 /var/lib/snapd -> /home/snapd
