η κυρια εχει εδω και μερικες μερες για αγνωστο λογο μια καθετη μαυρη μπαρα ενος εκατοστου δεξια στο λαπτοπ.
inxi -F
System: Host: Vostro-3558 Kernel: 5.4.0-91-generic x86_64 bits: 64 Desktop: Cinnamon 5.0.7
Distro: Linux Mint 20.2 Uma
Machine: Type: Laptop System: Dell product: Vostro 3558 v: N/A serial: <superuser/root required>
Mobo: Dell model: 05W6N2 v: A00 serial: <superuser/root required> UEFI: Dell v: A17
date: 09/11/2020
Battery: ID-1: BAT0 charge: 26.7 Wh condition: 26.7/41.4 Wh (64%)
CPU: Topology: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP L2 cache: 3072 KiB
Speed: 797 MHz min/max: 500/1900 MHz Core speeds (MHz): 1: 798 2: 799 3: 798 4: 798
Graphics: Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
Display: x11 server: X.Org 1.20.11 driver: modesetting unloaded: fbdev,vesa tty: N/A
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.0.3
Audio: Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.0-91-generic
Network: Device-1: Intel Wireless 3160 driver: iwlwifi
IF: wlp6s0 state: up mac: 2c:6e:85:bc:01:92
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp7s0 state: down mac: 84:7b:eb:2a:35:3f
Drives: Local Storage: total: 232.89 GiB used: 63.91 GiB (27.4%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 24.16 GiB used: 13.12 GiB (54.3%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 199.75 GiB used: 50.74 GiB (25.4%) fs: ext4 dev: /dev/sda3
ID-3: swap-1 size: 4.16 GiB used: 45.2 MiB (1.1%) fs: swap dev: /dev/sda4
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A sodimm: 2.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0 fan-3: 0
Info: Processes: 213 Uptime: 3h 06m Memory: 3.76 GiB used: 2.38 GiB (63.3%) Shell: bash
inxi: 3.0.38
xrandr --prop
Screen 0: minimum 320 x 200, current 1360 x 768, maximum 16384 x 16384
eDP-1 connected primary 1360x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
EDID:
00ffffffffffff0009e5200600000000
01180104952213780a24109759548e27
1e505400000001010101010101010101
010101010101641b5677500013303020
360058c21000001aa21756b950002d30
3020360058c21000001a000000fe0050
444a4a48804e54313536574800000000
00004101940010000009010a2020009c
scaling mode: Full aspect
supported: Full, Center, Full aspect
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 68
supported: 68
non-desktop: 0
range: (0, 1)
1366x768 60.00 + 47.98
1360x768 59.80 59.96*
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
max bpc: 12
range: (6, 12)
audio: auto
supported: force-dvi, off, auto, on
link-status: Good
CONNECTOR_ID: 74
supported: 74
non-desktop: 0
range: (0, 1)
HDMI-1 disconnected (normal left inverted right x axis y axis)
max bpc: 12
range: (8, 12)
content type: No Data
supported: No Data, Graphics, Photo, Cinema, Game
Colorspace: Default
supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
link-status: Good
CONNECTOR_ID: 80
supported: 80
non-desktop: 0
range: (0, 1)
Ευχαριστω για οποιαδηποτε βοηθεια.
