και η συνεχεια
[cmdline] 0.626761] PCI: CLS 64 bytes, default 64
[ 0.626808] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.626810] software IO TLB: mapped [mem 0x0000000087512000-0x000000008b512000] (64MB)
[ 0.626846] Trying to unpack rootfs image as initramfs…
[ 0.627992] Initialise system trusted keyrings
[ 0.628005] Key type blacklist registered
[ 0.628062] workingset: timestamp_bits=36 max_order=21 bucket_order=0
[ 0.630689] zbud: loaded
[ 0.631167] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.631421] fuse: init (API version 7.34)
[ 0.631712] integrity: Platform Keyring initialized
[ 0.647392] Key type asymmetric registered
[ 0.647395] Asymmetric key parser ‘x509’ registered
[ 0.647421] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.647479] io scheduler mq-deadline registered
[ 0.648399] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[ 0.648884] pcieport 0000:00:1c.5: AER: enabled with IRQ 123
[ 0.649348] pcieport 0000:00:1d.0: AER: enabled with IRQ 124
[ 0.649494] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.651221] ACPI: AC: AC Adapter [ACAD] (on-line)
[ 0.651343] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/PNP0C0D:00/input/input0
[ 0.651378] ACPI: button: Lid Switch [LID0]
[ 0.651454] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.651510] ACPI: button: Power Button [PWRF]
[ 0.654892] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.654897] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.655398] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.655402] ACPI: thermal: Thermal Zone [TZ01] (30 C)
[ 0.655609] thermal LNXTHERM:02: registered as thermal_zone2
[ 0.655612] ACPI: thermal: Thermal Zone [TZ02] (10 C)
[ 0.656073] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.659314] hpet_acpi_add: no address or irqs in _CRS
[ 0.659394] Linux agpgart interface v0.103
[ 0.677628] loop: module loaded
[ 0.678151] tun: Universal TUN/TAP device driver, 1.6
[ 0.678238] PPP generic driver version 2.4.2
[ 0.678414] VFIO - User Level meta-driver version: 0.3
[ 0.678565] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.678571] ehci-pci: EHCI PCI platform driver
[ 0.678585] ehci-platform: EHCI generic platform driver
[ 0.678601] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.678604] ohci-pci: OHCI PCI platform driver
[ 0.678617] ohci-platform: OHCI generic platform driver
[ 0.678628] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.678718] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.700737] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.700750] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.701046] mousedev: PS/2 mouse device common for all mice
[ 0.701373] rtc_cmos 00:03: RTC can wake from S4
[ 0.702059] rtc_cmos 00:03: registered as rtc0
[ 0.702190] rtc_cmos 00:03: setting system clock to 2023-02-18T15:45:18 UTC (1676735118)
[ 0.702218] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram
[ 0.702234] i2c_dev: i2c /dev entries driver
[ 0.702806] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 0.702852] device-mapper: uevent: version 1.0.3
[ 0.702989] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.703025] platform eisa.0: Probing EISA bus 0
[ 0.703028] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.703031] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.703034] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.703036] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.703039] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.703041] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.703043] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.703046] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.703048] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.703050] platform eisa.0: EISA: Detected 0 cards
[ 0.703066] intel_pstate: Intel P-state driver initializing
[ 0.703550] intel_pstate: HWP enabled
[ 0.703814] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.703846] efifb: probing for efifb
[ 0.703869] efifb: showing boot graphics
[ 0.704698] efifb: framebuffer at 0xa0000000, using 8100k, total 8100k
[ 0.704700] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.704702] efifb: scrolling: redraw
[ 0.704703] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.704861] Console: switching to colour frame buffer device 240x67
[ 0.709979] fb0: EFI VGA frame buffer device
[ 0.710002] EFI Variables Facility v0.08 2004-May-17
[ 0.717484] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 0.731701] ACPI: battery: Slot [BAT1] (battery present)
[ 0.756428] intel_pmc_core INT33A1:00: initialized
[ 0.756508] drop_monitor: Initializing network drop monitor service
[ 0.756649] NET: Registered PF_INET6 protocol family
[ 1.304318] Freeing initrd memory: 120756K
[ 1.310265] Segment Routing with IPv6
[ 1.310276] In-situ OAM (IOAM) with IPv6
[ 1.310299] NET: Registered PF_PACKET protocol family
[ 1.310333] Key type dns_resolver registered
[ 1.311044] microcode: sig=0x806ea, pf=0x80, revision=0xf0
[ 1.311270] microcode: Microcode Update Driver: v2.2.
[ 1.311274] IPI shorthand broadcast: enabled
[ 1.311282] sched_clock: Marking stable (1304763776, 6502702)->(1381837813, -70571335)
[ 1.311520] registered taskstats version 1
[ 1.311772] Loading compiled-in X.509 certificates
[ 1.312347] Loaded X.509 cert ‘Build time autogenerated kernel key: 2453f7d92edfc2f639f43e9f3b2f2940ca2143ea’
[ 1.312788] Loaded X.509 cert ‘Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969’
[ 1.313223] Loaded X.509 cert ‘Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19’
[ 1.313224] blacklist: Loading compiled-in revocation X.509 certificates
[ 1.313238] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0’
[ 1.313250] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03’
[ 1.313262] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b’
[ 1.313274] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8’
[ 1.313287] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d’
[ 1.313299] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c’
[ 1.313311] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af’
[ 1.313323] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9’
[ 1.313468] zswap: loaded using pool lzo/zbud
[ 1.313799] Key type .fscrypt registered
[ 1.313800] Key type fscrypt-provisioning registered
[ 1.314028] Key type trusted registered
[ 1.316953] Key type encrypted registered
[ 1.316956] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.318172] integrity: Loading X.509 certificate: UEFI:MokListRT (MOKvar table)
[ 1.318505] integrity: Loaded X.509 cert ‘Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63’
[ 1.318510] Loading compiled-in module X.509 certificates
[ 1.318945] Loaded X.509 cert ‘Build time autogenerated kernel key: 2453f7d92edfc2f639f43e9f3b2f2940ca2143ea’
[ 1.318947] ima: Allocated hash algorithm: sha1
[ 1.356170] ima: No architecture policies found
[ 1.356193] evm: Initialising EVM extended attributes:
[ 1.356194] evm: security.selinux
[ 1.356196] evm: security.SMACK64
[ 1.356198] evm: security.SMACK64EXEC
[ 1.356199] evm: security.SMACK64TRANSMUTE
[ 1.356201] evm: security.SMACK64MMAP
[ 1.356202] evm: security.apparmor
[ 1.356203] evm: security.ima
[ 1.356205] evm: security.capability
[ 1.356206] evm: HMAC attrs: 0x1
[ 1.356872] PM: Magic number: 11:155:791
[ 1.357286] RAS: Correctable Errors collector initialized.
[ 1.359809] Freeing unused decrypted memory: 2036K
[ 1.360834] Freeing unused kernel image (initmem) memory: 3240K
[ 1.379762] Write protecting the kernel read-only data: 30720k
[ 1.380977] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.381609] Freeing unused kernel image (rodata/data gap) memory: 1468K
[ 1.446936] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.446937] x86/mm: Checking user space page tables
[ 1.489674] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.489678] Run /init as init process
[ 1.489679] with arguments:
[ 1.489680] /init
[ 1.489681] splash
[ 1.489682] with environment:
[ 1.489683] HOME=/
[ 1.489683] TERM=linux
[ 1.489684] BOOT_IMAGE=/boot/vmlinuz-5.15.0-60-generic
[ 1.590785] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.590795] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.591012] ahci 0000:00:17.0: version 3.0
[ 1.591360] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl RAID mode
[ 1.591366] ahci 0000:00:17.0: flags: 64bit ncq ilck pm led clo only pio slum part deso sadm sds apst
[ 1.591873] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[ 1.592242] wmi_bus wmi_bus-PNP0C14:01: WQBJ data block query control method not found
[ 1.593621] scsi host0: ahci
[ 1.593723] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.593729] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.593733] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.593775] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.593778] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.593780] usb usb1: Product: xHCI Host Controller
[ 1.593782] usb usb1: Manufacturer: Linux 5.15.0-60-generic xhci-hcd
[ 1.593785] usb usb1: SerialNumber: 0000:00:14.0
[ 1.593788] scsi host1: ahci
[ 1.593881] ata1: SATA max UDMA/133 abar m2048@0xb1335000 port 0xb1335100 irq 125
[ 1.593886] ata2: SATA max UDMA/133 abar m2048@0xb1335000 port 0xb1335180 irq 125
[ 1.595442] hub 1-0:1.0: USB hub found
[ 1.595460] hub 1-0:1.0: 12 ports detected
[ 1.597707] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.597713] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.597715] usb usb2: Product: xHCI Host Controller
[ 1.597718] usb usb2: Manufacturer: Linux 5.15.0-60-generic xhci-hcd
[ 1.597719] usb usb2: SerialNumber: 0000:00:14.0
[ 1.597971] hub 2-0:1.0: USB hub found
[ 1.597985] hub 2-0:1.0: 6 ports detected
[ 1.598691] usb: port power management may be unreliable
[ 1.604382] cryptd: max_cpu_qlen set to 1000
[ 1.610059] AVX2 version of gcm_enc/dec engaged.
[ 1.610107] AES CTR mode by8 optimization enabled
[ 1.611102] r8169 0000:01:00.0 eth0: RTL8168h/8111h, e4:e7:49:0b:1b:82, XID 541, IRQ 127
[ 1.611108] r8169 0000:01:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 1.627557] tsc: Refined TSC clocksource calibration: 1799.997 MHz
[ 1.627563] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x19f226b2958, max_idle_ns: 440795203083 ns
[ 1.627594] clocksource: Switched to clocksource tsc
[ 1.906818] ata1: SATA link down (SStatus 4 SControl 300)
[ 1.910851] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.916543] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 1.916616] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 1.917393] r8169 0000:01:00.0 eno1: renamed from eth0
[ 1.920032] nvme nvme0: pci function 0000:03:00.0
[ 1.927514] i2c i2c-0: 1/2 memory slots populated (from DMI)
[ 1.927993] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 1.934604] nvme nvme0: allocated 38 MiB host memory buffer.
[ 1.935583] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[ 1.965896] nvme nvme0: 8/0/0 default/read/poll queues
[ 1.973513] nvme0n1: p1 p2 p3 p4
[ 2.088877] usb 1-1: New USB device found, idVendor=2357, idProduct=0604, bcdDevice= 2.00
[ 2.088891] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.088897] usb 1-1: Product: TP-Link UB500 Adapter
[ 2.088902] usb 1-1: Manufacturer:
[ 2.088906] usb 1-1: SerialNumber: E848B8C82000
[ 2.160865] Console: switching to colour dummy device 80x25
[ 2.160909] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 2.163404] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 2.163833] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 2.215669] usb 1-2: new full-speed USB device number 3 using xhci_hcd
[ 2.221099] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 2.224951] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 2.227435] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[ 2.374725] usb 1-2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.00
[ 2.374728] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.374730] usb 1-2: Product: USB Receiver
[ 2.374731] usb 1-2: Manufacturer: Logitech
[ 2.383441] psmouse serio1: synaptics: queried max coordinates: x […5648], y […4826]
[ 2.413360] psmouse serio1: synaptics: queried min coordinates: x [1292…], y [1026…]
[ 2.413365] psmouse serio1: synaptics: Your touchpad (PNP: SYN3278 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 2.471956] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.16, id: 0x1e2b1, caps: 0xf00323/0x840300/0x2e800/0x400000, board id: 3320, fw id: 2659795
[ 2.509636] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input4
[ 2.511597] usb 1-5: new high-speed USB device number 4 using xhci_hcd
[ 2.679528] usb 1-5: New USB device found, idVendor=04f2, idProduct=b62a, bcdDevice=18.14
[ 2.679541] usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.679560] usb 1-5: Product: HP Webcam
[ 2.679565] usb 1-5: Manufacturer: Chicony Electronics Co.,Ltd.
[ 2.679570] usb 1-5: SerialNumber: 0x0001
[ 2.695923] fbcon: i915drmfb (fb0) is primary device
[ 2.807722] usb 1-6: new full-speed USB device number 5 using xhci_hcd
[ 2.956983] usb 1-6: New USB device found, idVendor=0bda, idProduct=b00a, bcdDevice= 1.10
[ 2.956996] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.957001] usb 1-6: Product: Bluetooth Radio
[ 2.957005] usb 1-6: Manufacturer: Realtek
[ 2.957009] usb 1-6: SerialNumber: 00e04c000001
[ 2.972815] hid: raw HID events driver (C) Jiri Kosina
[ 2.982248] usbcore: registered new interface driver usbhid
[ 2.982250] usbhid: USB HID core driver
[ 4.322099] Console: switching to colour frame buffer device 240x67
[ 4.346436] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 4.367641] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C52B.0001/input/input6
[ 4.431617] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-2/input0
[ 4.431780] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input7
[ 4.431856] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input8
[ 4.495590] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input9
[ 4.495661] hid-generic 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-2/input1
[ 4.495775] hid-generic 0003:046D:C52B.0003: hiddev1,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2
[ 4.688778] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2
[ 4.809997] input: Logitech Wireless Device PID:101b Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:101B.0004/input/input11
[ 4.810420] hid-generic 0003:046D:101B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Wireless Device PID:101b] on usb-0000:00:14.0-2/input2:1
[ 4.875259] input: Logitech M705 as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:101B.0004/input/input15
[ 4.875491] logitech-hidpp-device 0003:046D:101B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M705] on usb-0000:00:14.0-2/input2:1
[ 5.763544] raid6: avx2x4 gen() 26694 MB/s
[ 5.831545] raid6: avx2x4 xor() 11841 MB/s
[ 5.899544] raid6: avx2x2 gen() 35790 MB/s
[ 5.967544] raid6: avx2x2 xor() 22104 MB/s
[ 6.035544] raid6: avx2x1 gen() 22765 MB/s
[ 6.103545] raid6: avx2x1 xor() 15591 MB/s
[ 6.171544] raid6: sse2x4 gen() 15457 MB/s
[ 6.239545] raid6: sse2x4 xor() 8864 MB/s
[ 6.307545] raid6: sse2x2 gen() 15676 MB/s
[ 6.375545] raid6: sse2x2 xor() 9683 MB/s
[ 6.443544] raid6: sse2x1 gen() 13294 MB/s
[ 6.511545] raid6: sse2x1 xor() 6664 MB/s
[ 6.511546] raid6: using algorithm avx2x2 gen() 35790 MB/s
[ 6.511547] raid6: … xor() 22104 MB/s, rmw enabled
[ 6.511548] raid6: using avx2x2 recovery algorithm
[ 6.514804] xor: automatically using best checksumming function avx
[ 6.541199] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[ 6.606113] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 6.839664] systemd[1]: Inserted module ‘autofs4’
[ 6.954136] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 6.971897] systemd[1]: Detected architecture x86-64.
[ 7.249584] systemd[1]: Queued start job for default target Graphical Interface.
[ 7.250846] systemd[1]: Created slice Slice /system/modprobe.
[ 7.251160] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 7.251413] systemd[1]: Created slice User and Session Slice.
[ 7.251483] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.251645] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.251709] systemd[1]: Reached target User and Group Name Lookups.
[ 7.251729] systemd[1]: Reached target Remote File Systems.
[ 7.251740] systemd[1]: Reached target Slice Units.
[ 7.251765] systemd[1]: Reached target Local Verity Protected Volumes.
[ 7.251840] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.251934] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.252013] systemd[1]: Listening on Syslog Socket.
[ 7.252926] systemd[1]: Listening on Process Core Dump Socket.
[ 7.253004] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.253051] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.253228] systemd[1]: Listening on Journal Audit Socket.
[ 7.253323] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.253423] systemd[1]: Listening on Journal Socket.
[ 7.253665] systemd[1]: Listening on udev Control Socket.
[ 7.253752] systemd[1]: Listening on udev Kernel Socket.
[ 7.254453] systemd[1]: Mounting Huge Pages File System…
[ 7.255127] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.255840] systemd[1]: Mounting Kernel Debug File System…
[ 7.256521] systemd[1]: Mounting Kernel Trace File System…
[ 7.257984] systemd[1]: Starting Journal Service…
[ 7.258124] systemd[1]: Finished Availability of block devices.
[ 7.259096] systemd[1]: Starting Set the console keyboard layout…
[ 7.260002] systemd[1]: Starting Create List of Static Device Nodes…
[ 7.260823] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 7.261796] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 7.262848] systemd[1]: Starting Load Kernel Module configfs…
[ 7.263726] systemd[1]: Starting Load Kernel Module drm…
[ 7.264767] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 7.265939] systemd[1]: Starting Load Kernel Module fuse…
[ 7.267337] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 7.268590] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 7.270443] systemd[1]: Starting Load Kernel Module ramoops…
[ 7.270746] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.273583] systemd[1]: Starting Load Kernel Modules…
[ 7.275536] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.277068] systemd[1]: Starting Coldplug All udev Devices…
[ 7.280534] systemd[1]: Mounted Huge Pages File System.
[ 7.280965] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.281158] systemd[1]: Mounted Kernel Debug File System.
[ 7.281433] systemd[1]: Mounted Kernel Trace File System.
[ 7.282001] systemd[1]: Finished Create List of Static Device Nodes.
[ 7.282618] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 7.282914] systemd[1]: Finished Load Kernel Module configfs.
[ 7.283332] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 7.283572] systemd[1]: Finished Load Kernel Module drm.
[ 7.283885] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 7.284143] systemd[1]: Finished Load Kernel Module fuse.
[ 7.284193] EXT4-fs (nvme0n1p2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 7.285142] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[ 7.285445] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 7.285767] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[ 7.286036] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 7.286335] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[ 7.286804] systemd[1]: Finished Load Kernel Module ramoops.
[ 7.288337] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 7.289635] systemd[1]: Mounting FUSE Control File System…
[ 7.291403] systemd[1]: Mounting Kernel Configuration File System…
[ 7.293289] systemd[1]: Starting Load/Save Random Seed…
[ 7.294752] lp: driver loaded but no devices found
[ 7.295112] systemd[1]: Starting Create System Users…
[ 7.296605] systemd[1]: Mounted FUSE Control File System.
[ 7.299615] systemd[1]: Mounted Kernel Configuration File System.
[ 7.308055] systemd[1]: Finished Load/Save Random Seed.
[ 7.308231] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 7.314158] systemd[1]: Finished Create System Users.
[ 7.318499] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 7.319751] pstore: Using crash dump compression: deflate
[ 7.319766] pstore: Registered efi as persistent store backend
[ 7.327393] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 7.329067] systemd[1]: Starting Rule-based Manager for Device Events and Files…
[ 7.336691] systemd[1]: Started Journal Service.
[ 7.342429] ppdev: user-space parallel port driver
[ 7.342714] systemd-journald[399]: Received client request to flush runtime journal.
[ 7.543991] input: Wireless hotkeys as /devices/virtual/input/input16
[ 7.646610] acpi INT33D6:00: intel-vbtn: created platform device
[ 7.648915] intel-vbtn INT33D6:00: failed to read Intel Virtual Button driver
[ 7.671253] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 7.676791] mei_me 0000:00:16.0: enabling device (0004 → 0006)
[ 7.679554] Bluetooth: Core ver 2.22
[ 7.680078] NET: Registered PF_BLUETOOTH protocol family
[ 7.680081] Bluetooth: HCI device and connection manager initialized
[ 7.680085] Bluetooth: HCI socket layer initialized
[ 7.680087] Bluetooth: L2CAP socket layer initialized
[ 7.680093] Bluetooth: SCO socket layer initialized
[ 7.698729] mc: Linux media interface: v0.10
[ 7.715353] videodev: Linux video capture interface: v2.00
[ 7.726410] Adding 4381692k swap on /dev/nvme0n1p4. Priority:-2 extents:1 across:4381692k SSFS
[ 7.736544] intel_rapl_common: Found RAPL domain package
[ 7.736548] intel_rapl_common: Found RAPL domain dram
[ 7.765142] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[ 7.766136] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 7.766140] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_fw.bin
[ 7.766169] Bluetooth: hci1: RTL: examining hci_ver=08 hci_rev=75b8 lmp_ver=08 lmp_subver=f098
[ 7.766172] Bluetooth: hci1: RTL: unknown IC info, lmp subver f098, hci rev 75b8, hci ver 0008
[ 7.766173] Bluetooth: hci1: RTL: assuming no firmware upload needed
[ 7.768492] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_config.bin
[ 7.768568] Bluetooth: hci0: RTL: cfg_sz 6, total sz 27814
[ 7.770039] usbcore: registered new interface driver btusb
[ 7.772300] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 7.772304] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 7.772305] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 7.772307] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 7.772308] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 7.772309] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 7.786273] usb 1-5: Found UVC 1.00 device HP Webcam (04f2:b62a)
[ 7.797925] input: HP Webcam: HP Webcam as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input18
[ 7.798068] usbcore: registered new interface driver uvcvideo
[ 7.815900] EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 7.822873] intel_tcc_cooling: Programmable TCC Offset detected
[ 7.834570] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 7.834820] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 7.878661] intel_rapl_common: Found RAPL domain package
[ 7.878665] intel_rapl_common: Found RAPL domain core
[ 7.878667] intel_rapl_common: Found RAPL domain uncore
[ 7.878668] intel_rapl_common: Found RAPL domain dram
[ 7.878670] intel_rapl_common: Found RAPL domain psys
[ 7.894987] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 7.898157] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC236: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 7.898162] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 7.898164] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 7.898166] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 7.898167] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 7.898168] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 7.898169] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 7.910151] Bluetooth: hci0: RTL: fw version 0x09a98a6b
[ 7.951936] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 7.952022] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 7.952097] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 7.952159] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 7.952212] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 7.952264] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 7.952316] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 8.232999] input: HP WMI hotkeys as /devices/virtual/input/input17
[ 8.772859] spl: loading out-of-tree module taints kernel.
[ 8.787473] znvpair: module license ‘CDDL’ taints kernel.
[ 8.787481] Disabling lock debugging due to kernel taint
[ 8.957571] ZFS: Loaded module v2.1.4-0ubuntu0.1, ZFS pool version 5000, ZFS filesystem version 5
[ 9.002071] audit: type=1400 audit(1676735126.789:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=679 comm=“apparmor_parser”
[ 9.002076] audit: type=1400 audit(1676735126.789:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=679 comm=“apparmor_parser”
[ 9.002078] audit: type=1400 audit(1676735126.789:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/bin/man” pid=681 comm=“apparmor_parser”
[ 9.002081] audit: type=1400 audit(1676735126.789:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“man_filter” pid=681 comm=“apparmor_parser”
[ 9.002083] audit: type=1400 audit(1676735126.789:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“man_groff” pid=681 comm=“apparmor_parser”
[ 9.002085] audit: type=1400 audit(1676735126.789:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lsb_release” pid=678 comm=“apparmor_parser”
[ 9.002087] audit: type=1400 audit(1676735126.789:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“libreoffice-oosplash” pid=684 comm=“apparmor_parser”
[ 9.002090] audit: type=1400 audit(1676735126.789:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/bin/redshift” pid=682 comm=“apparmor_parser”
[ 9.002092] audit: type=1400 audit(1676735126.793:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“libreoffice-senddoc” pid=685 comm=“apparmor_parser”
[ 9.002095] audit: type=1400 audit(1676735126.793:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“libreoffice-xpdfimport” pid=687 comm=“apparmor_parser”
[ 9.274297] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.274302] Bluetooth: BNEP filters: protocol multicast
[ 9.274306] Bluetooth: BNEP socket layer initialized
[ 9.283455] NET: Registered PF_ALG protocol family
[ 9.447596] Generic FE-GE Realtek PHY r8169-0-100:00: attached PHY driver (mii_bus:phy_addr=r8169-0-100:00, irq=MAC)
[ 9.652095] r8169 0000:01:00.0 eno1: Link is Down
[ 12.387452] Bluetooth: RFCOMM TTY layer initialized
[ 12.387461] Bluetooth: RFCOMM socket layer initialized
[ 12.387465] Bluetooth: RFCOMM ver 1.11
[ 14.021205] logitech-hidpp-device 0003:046D:101B.0004: HID++ 1.0 device connected.
[ 15.671906] kauditd_printk_skb: 14 callbacks suppressed
[ 15.671908] audit: type=1400 audit(1676735133.465:26): apparmor=“DENIED” operation=“capable” profile=“/usr/sbin/cups-browsed” pid=1418 comm=“cups-browsed” capability=23 capname=“sys_nice”
[/cmdline]
