στο λαπτοπ της φιλης μου εδω και μια βδομαδα χωρις συγκεκριμενο λογο παγωνει το συστημα και το ποντικι και μονο με επανεκκίνηση λυνεται το προβλημα.
Δοκιμασα απενεργοποιηση των εφε και του τιλιγκ παραθυρων αλλα δεν μασαει.
System:
Host: renatko-HP-Laptop-15-da0xxx Kernel: 5.15.0-70-generic x86_64 bits: 64
Desktop: Cinnamon 5.6.8 Distro: Linux Mint 21.1 Vera
Machine:
Type: Laptop System: HP product: HP Laptop 15-da0xxx
v: Type1ProductConfigId serial: <superuser required>
Mobo: HP model: 84A6 v: 80.28 serial: <superuser required> UEFI: Insyde
v: F.04 date: 08/02/2018
Battery:
ID-1: BAT1 charge: 31.4 Wh (100.0%) condition: 31.4/41.9 Wh (74.9%)
CPU:
Info: quad core model: Intel Core i5-8250U bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 1250 min/max: 400/3400 cores: 1: 800 2: 800 3: 795
4: 800 5: 800 6: 1868 7: 3341 8: 796
Graphics:
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: Chicony HP Webcam type: USB driver: uvcvideo
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 22.2.5
Audio:
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.0-70-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: eno1 state: down mac: e4:e7:49:0b:1b:82
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce
IF: wlo1 state: up mac: d8:9c:67:78:3f:3f
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
Report: hciconfig ID: hci0 state: up address: D8:9C:67:78:3F:40 bt-v: 2.1
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
Drives:
Local Storage: total: 238.47 GiB used: 59.49 GiB (24.9%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 238.47 GiB
Partition:
ID-1: / size: 28.41 GiB used: 10.99 GiB (38.7%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 498.7 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 200.5 GiB used: 48.49 GiB (24.2%) fs: ext4
dev: /dev/nvme0n1p3
Swap:
ID-1: swap-1 type: partition size: 4.18 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p4
Sensors:
System Temperatures: cpu: 29.8 C pch: 40.5 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Info:
Processes: 282 Uptime: 5m Memory: 7.68 GiB used: 2.49 GiB (32.4%)
Shell: Bash inxi: 3.3.13
και το syslog
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx kernel: [ 20.201608] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx kernel: [ 20.201706] audit: type=1107 audit(1682193696.011:32): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="StartServiceByName" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx kernel: [ 20.201706] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx kernel: [ 20.202097] audit: type=1107 audit(1682193696.011:33): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="GetNameOwner" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx kernel: [ 20.202097] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx kernel: [ 20.202471] audit: type=1107 audit(1682193696.011:34): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/GeoClue2/Manager" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.67" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx kernel: [ 20.202471] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating via systemd: service name='org.gnome.evolution.dataserver.Calendar8' unit='evolution-calendar-factory.service' requested by ':1.51' (uid=1000 pid=1609 comm="/usr/libexec/evolution-data-server/evolution-alarm" label="unconfined")
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx systemd[1127]: Starting Evolution calendar service...
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.50' (uid=1000 pid=1595 comm="/usr/bin/python3 /usr/bin/blueman-applet " label="unconfined")
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx systemd[1127]: Starting Bluetooth OBEX service...
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx obexd[1686]: OBEX daemon 5.64
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.bluez.obex'
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx systemd[1127]: Started Bluetooth OBEX service.
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.gnome.evolution.dataserver.Calendar8'
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx systemd[1127]: Started Evolution calendar service.
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating via systemd: service name='org.gnome.evolution.dataserver.AddressBook10' unit='evolution-addressbook-factory.service' requested by ':1.56' (uid=1000 pid=1680 comm="/usr/libexec/evolution-calendar-factory " label="unconfined")
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx systemd[1127]: Starting Evolution address book service...
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating service name='org.cinnamon.CalendarServer' requested by ':1.42' (uid=1000 pid=1541 comm="cinnamon --replace " label="unconfined")
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx cinnamon-session[1137]: WARNING: t+1,79370s: Detected that screensaver has appeared on the bus
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.gnome.evolution.dataserver.AddressBook10'
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx systemd[1127]: Started Evolution address book service.
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.cinnamon.CalendarServer'
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: Reject scan trigger since one is already pending
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx bluetoothd[1211]: /org/bluez/hci0/dev_E8_D0_3C_31_3D_F2/fd0: fd(29) ready
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 4 threads of 2 processes of 1 users.
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Successfully made thread 1748 of process 1136 owned by '1000' RT at priority 5.
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 5 threads of 2 processes of 1 users.
Apr 22 22:01:36 renatko-HP-Laptop-15-da0xxx pulseaudio[1136]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_E8_D0_3C_31_3D_F2/fd0 Volume failed: org.freedesktop.DBus.Error.InvalidArgs: No such property 'Volume'
Apr 22 22:01:37 renatko-HP-Laptop-15-da0xxx kernel: [ 21.222809] input: JBL Flip 5 (AVRCP) as /devices/virtual/input/input9
Apr 22 22:01:37 renatko-HP-Laptop-15-da0xxx systemd[1]: dmesg.service: Deactivated successfully.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0558] policy: auto-activating connection 'Automatyczne FRITZ!Box 7530 AM' (e43e49c1-636f-4dc9-8ff1-9d07e490a839)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0565] device (wlo1): Activation: starting connection 'Automatyczne FRITZ!Box 7530 AM' (e43e49c1-636f-4dc9-8ff1-9d07e490a839)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0566] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0570] manager: NetworkManager state is now CONNECTING
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0573] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0577] device (wlo1): Activation: (wifi) access point 'Automatyczne FRITZ!Box 7530 AM' has security, but secrets are required.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0578] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0580] sup-iface[7b7dce9feb37f41d,0,wlo1]: wps: type pbc start...
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0594] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0598] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0601] device (wlo1): Activation: (wifi) connection 'Automatyczne FRITZ!Box 7530 AM' has security, and secrets exist. No new secrets needed.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0602] Config: added 'ssid' value 'FRITZ!Box 7530 AM'
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0602] Config: added 'scan_ssid' value '1'
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0602] Config: added 'bgscan' value 'simple:30:-70:86400'
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0602] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.0602] Config: added 'psk' value '<hidden>'
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: WPS-CANCEL
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: SME: Trying to authenticate with 98:9b:cb:c3:71:9b (SSID='FRITZ!Box 7530 AM' freq=5580 MHz)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 22.259454] wlo1: authenticate with 98:9b:cb:c3:71:9b
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.46' (uid=1000 pid=1604 comm="nemo-desktop " label="unconfined")
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1127]: Starting Virtual filesystem metadata service...
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.gtk.vfs.Metadata'
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1127]: Started Virtual filesystem metadata service.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.6171] device (wlo1): supplicant interface state: disconnected -> authenticating
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 22.799798] wlo1: send auth to 98:9b:cb:c3:71:9b (try 1/3)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: Trying to associate with 98:9b:cb:c3:71:9b (SSID='FRITZ!Box 7530 AM' freq=5580 MHz)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.7223] device (wlo1): supplicant interface state: authenticating -> associating
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 22.903680] wlo1: send auth to 98:9b:cb:c3:71:9b (try 2/3)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 22.905922] wlo1: authenticated
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 22.907612] wlo1: associate with 98:9b:cb:c3:71:9b (try 1/3)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: Associated with 98:9b:cb:c3:71:9b
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 22.911748] wlo1: RX AssocResp from 98:9b:cb:c3:71:9b (capab=0x1511 status=0 aid=1)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 22.911762] rtw_8821ce 0000:02:00.0: sta 98:9b:cb:c3:71:9b joined with macid 0
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 22.912081] wlo1: associated
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.7336] device (wlo1): supplicant interface state: associating -> associated
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.7446] device (wlo1): supplicant interface state: associated -> 4way_handshake
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: WPA: Key negotiation completed with 98:9b:cb:c3:71:9b [PTK=CCMP GTK=CCMP]
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: CTRL-EVENT-CONNECTED - Connection to 98:9b:cb:c3:71:9b completed [id=0 id_str=]
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8405] device (wlo1): supplicant interface state: 4way_handshake -> completed
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8405] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "FRITZ!Box 7530 AM"
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8406] device (wlo1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8411] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::7ac2:66b0:ef13:d05f.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: New relevant interface wlo1.IPv6 for mDNS.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Registering new address record for fe80::7ac2:66b0:ef13:d05f on wlo1.*.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 23.023636] wlo1: Limiting TX power to 27 (30 - 3) dBm as advertised by 98:9b:cb:c3:71:9b
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 23.023701] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8568] dhcp4 (wlo1): state changed new lease, address=192.168.178.49
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.178.49.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: New relevant interface wlo1.IPv4 for mDNS.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Registering new address record for 192.168.178.49 on wlo1.IPv4.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8590] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8617] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8619] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8622] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8627] manager: NetworkManager state is now CONNECTED_SITE
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8628] policy: set 'Automatyczne FRITZ!Box 7530 AM' (wlo1) as default for IPv4 routing and DNS
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8636] device (wlo1): Activation: successful, device activated.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd-resolved[917]: wlo1: Bus client set search domain list to: fritz.box
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd-resolved[917]: wlo1: Bus client set default route setting: yes
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd-resolved[917]: wlo1: Bus client set DNS server list to: 192.168.178.1
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193698.8909] manager: startup complete
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Finished Network Manager Wait Online.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Reached target Network is Online.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Started Make remote CUPS printers available locally.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Starting Tool to automatically collect and submit kernel crash signatures...
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Condition check resulted in Ubuntu Pro Background Auto Attach being skipped.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx nm-dispatcher[1865]: /etc/network/if-up.d/resolved: 12: mystatedir: not found
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: kerneloops.service: Found left-over process 1870 (kerneloops) in control group while starting unit. Ignoring.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd-resolved[917]: Using degraded feature set UDP instead of UDP+EDNS0 for DNS server 192.168.178.1.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Started Tool to automatically collect and submit kernel crash signatures.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Reached target Multi-User System.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Reached target Graphical Interface.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Starting casper-md5check Verify Live ISO checksums...
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Starting Record Runlevel Change in UTMP...
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx casper-md5check[1884]: .fopen md5_file: No such file or directory
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx casper-md5check[1884]: Checking integrity, this may take some time (or try: fsck.mode=skip)
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: casper-md5check.service: Main process exited, code=exited, status=1/FAILURE
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: casper-md5check.service: Failed with result 'exit-code'.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Failed to start casper-md5check Verify Live ISO checksums.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: systemd-update-utmp-runlevel.service: Deactivated successfully.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 23.100585] kauditd_printk_skb: 1 callbacks suppressed
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx kernel: [ 23.100588] audit: type=1400 audit(1682193698.911:36): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=1867 comm="cups-browsed" capability=23 capname="sys_nice"
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx systemd[1]: Finished Record Runlevel Change in UTMP.
Apr 22 22:01:38 renatko-HP-Laptop-15-da0xxx nm-dispatcher[1907]: /etc/network/if-up.d/resolved: 12: mystatedir: not found
Apr 22 22:01:39 renatko-HP-Laptop-15-da0xxx wpa_supplicant[931]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-50 noise=9999 txrate=390000
Apr 22 22:01:39 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193699.1555] manager: NetworkManager state is now CONNECTED_GLOBAL
Apr 22 22:01:39 renatko-HP-Laptop-15-da0xxx kernel: [ 23.341267] audit: type=1107 audit(1682193699.151:37): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_signal" bus="system" path="/org/freedesktop/GeoClue2/Manager" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.67" mask="receive" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:01:39 renatko-HP-Laptop-15-da0xxx kernel: [ 23.341267] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating via systemd: service name='org.freedesktop.portal.Desktop' unit='xdg-desktop-portal.service' requested by ':1.70' (uid=1000 pid=1929 comm="/usr/lib/firefox/firefox " label="unconfined")
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd[1127]: Starting Portal service...
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating via systemd: service name='org.freedesktop.portal.Documents' unit='xdg-document-portal.service' requested by ':1.72' (uid=1000 pid=1980 comm="/usr/libexec/xdg-desktop-portal " label="unconfined")
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd[1127]: Starting flatpak document portal service...
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating via systemd: service name='org.freedesktop.impl.portal.PermissionStore' unit='xdg-permission-store.service' requested by ':1.73' (uid=1000 pid=1984 comm="/usr/libexec/xdg-document-portal " label="unconfined")
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd[1127]: Starting sandboxed app permission store...
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd[1127]: Started sandboxed app permission store.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.freedesktop.portal.Documents'
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd[1127]: Started flatpak document portal service.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gtk' unit='xdg-desktop-portal-gtk.service' requested by ':1.72' (uid=1000 pid=1980 comm="/usr/libexec/xdg-desktop-portal " label="unconfined")
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd[1127]: Starting Portal service (GTK/GNOME implementation)...
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd[1127]: Started Portal service (GTK/GNOME implementation).
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 4 threads of 2 processes of 1 users.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: message repeated 2 times: [ Supervising 4 threads of 2 processes of 1 users.]
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx dbus-daemon[1153]: [session uid=1000 pid=1153] Successfully activated service 'org.freedesktop.portal.Desktop'
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd[1127]: Started Portal service.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193700.6813] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193700.6817] policy: set 'Automatyczne FRITZ!Box 7530 AM' (wlo1) as default for IPv6 routing and DNS
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::7ac2:66b0:ef13:d05f.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Joining mDNS multicast group on interface wlo1.IPv6 with address 2a01:c22:b822:f900:730a:5f66:52cb:56fa.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Registering new address record for 2a01:c22:b822:f900:730a:5f66:52cb:56fa on wlo1.*.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Withdrawing address record for fe80::7ac2:66b0:ef13:d05f on wlo1.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx systemd-resolved[917]: wlo1: Bus client set DNS server list to: 192.168.178.1, fd00::9a9b:cbff:fec3:7198, 2a01:c22:b822:f900:9a9b:cbff:fec3:7198
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx NetworkManager[966]: <info> [1682193700.6916] dhcp6 (wlo1): state changed new lease
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx kernel: [ 25.051949] rtw_8821ce 0000:02:00.0: failed to dequeue 217 skb TX queue 1, BD=0x00000001, rp 37 -> 0
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx kernel: [ 25.052840] rtw_8821ce 0000:02:00.0: failed to dequeue 37 skb TX queue 1, BD=0x00270027, rp 0 -> 39
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: message repeated 5 times: [ Supervising 4 threads of 2 processes of 1 users.]
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Successfully made thread 2096 of process 1929 owned by '1000' RT at priority 10.
Apr 22 22:01:40 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 5 threads of 3 processes of 1 users.
Apr 22 22:01:42 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: message repeated 8 times: [ Supervising 5 threads of 3 processes of 1 users.]
Apr 22 22:01:42 renatko-HP-Laptop-15-da0xxx avahi-daemon[864]: Registering new address record for 2a01:c22:b822:f900:b3ec:d89a:cc51:5e64 on wlo1.*.
Apr 22 22:01:45 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 5 threads of 3 processes of 1 users.
Apr 22 22:01:45 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: message repeated 3 times: [ Supervising 5 threads of 3 processes of 1 users.]
Apr 22 22:01:45 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Successfully made thread 2294 of process 2191 owned by '1000' RT at priority 10.
Apr 22 22:01:45 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 6 threads of 4 processes of 1 users.
Apr 22 22:01:46 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: message repeated 4 times: [ Supervising 6 threads of 4 processes of 1 users.]
Apr 22 22:01:50 renatko-HP-Laptop-15-da0xxx systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Apr 22 22:01:51 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 6 threads of 4 processes of 1 users.
Apr 22 22:01:51 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: message repeated 3 times: [ Supervising 6 threads of 4 processes of 1 users.]
Apr 22 22:01:54 renatko-HP-Laptop-15-da0xxx systemd-timesyncd[653]: Initial synchronization to time server [2620:2d:4000:1::40]:123 (ntp.ubuntu.com).
Apr 22 22:01:55 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 6 threads of 4 processes of 1 users.
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.225237] audit: type=1107 audit(1682193716.024:38): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="AddMatch" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.225237] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.225390] audit: type=1107 audit(1682193716.024:39): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="AddMatch" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.225390] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.225576] audit: type=1107 audit(1682193716.024:40): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="StartServiceByName" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.225576] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.225833] audit: type=1107 audit(1682193716.024:41): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="GetNameOwner" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.225833] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.226229] audit: type=1107 audit(1682193716.024:42): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/GeoClue2/Client/1" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.67" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.226229] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.228813] audit: type=1107 audit(1682193716.028:43): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/GeoClue2/Client/1" interface="org.freedesktop.DBus.Properties" member="Set" mask="send" name=":1.67" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.228813] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.229628] audit: type=1107 audit(1682193716.028:44): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_signal" bus="system" path="/org/freedesktop/GeoClue2/Client/1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.67" mask="receive" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.229628] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.229982] audit: type=1107 audit(1682193716.028:45): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/GeoClue2/Client/1" interface="org.freedesktop.DBus.Properties" member="Set" mask="send" name=":1.67" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.229982] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.230592] audit: type=1107 audit(1682193716.028:46): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_signal" bus="system" path="/org/freedesktop/GeoClue2/Client/1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.67" mask="receive" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.230592] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.231737] audit: type=1107 audit(1682193716.032:47): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/GeoClue2/Client/1" interface="org.freedesktop.GeoClue2.Client" member="Start" mask="send" name=":1.67" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:01:56 renatko-HP-Laptop-15-da0xxx kernel: [ 40.231737] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:01:55 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: message repeated 5 times: [ Supervising 6 threads of 4 processes of 1 users.]
Apr 22 22:01:57 renatko-HP-Laptop-15-da0xxx org.cinnamon.CalendarServer[1715]: SET TIME: from 2023-03-27T00:00:00+02 to 2023-05-07T23:59:59+02
Apr 22 22:01:57 renatko-HP-Laptop-15-da0xxx org.cinnamon.CalendarServer[1715]: Discovered calendar: Osobiste
Apr 22 22:01:57 renatko-HP-Laptop-15-da0xxx org.cinnamon.CalendarServer[1715]: Discovered calendar: Urodziny i rocznice
Apr 22 22:01:58 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: Supervising 6 threads of 4 processes of 1 users.
Apr 22 22:02:03 renatko-HP-Laptop-15-da0xxx rtkit-daemon[1144]: message repeated 13 times: [ Supervising 6 threads of 4 processes of 1 users.]
Apr 22 22:02:03 renatko-HP-Laptop-15-da0xxx systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx cinnamon-session[1137]: WARNING: t+31,80540s: Detected that screensaver has left the bus
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx systemd[1]: blueman-mechanism.service: Deactivated successfully.
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042084] kauditd_printk_skb: 9 callbacks suppressed
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042086] audit: type=1107 audit(1682193726.781:57): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_signal" bus="system" path="/org/freedesktop/GeoClue2/Client/1" interface="org.freedesktop.GeoClue2.Client" member="LocationUpdated" name=":1.67" mask="receive" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042086] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042187] audit: type=1107 audit(1682193726.785:58): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_signal" bus="system" path="/org/freedesktop/GeoClue2/Client/1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.67" mask="receive" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042187] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042631] audit: type=1107 audit(1682193726.785:59): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="AddMatch" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042631] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042723] audit: type=1107 audit(1682193726.785:60): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="AddMatch" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042723] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042797] audit: type=1107 audit(1682193726.785:61): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="StartServiceByName" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.042797] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.043211] audit: type=1107 audit(1682193726.785:62): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="GetNameOwner" mask="send" name="org.freedesktop.DBus" pid=1646 label="/usr/bin/redshift" peer_label="unconfined"
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.043211] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.043641] audit: type=1107 audit(1682193726.785:63): pid=659 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_method_call" bus="system" path="/org/freedesktop/GeoClue2/Client/1/Location/1" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.67" pid=1646 label="/usr/bin/redshift" peer_pid=1659 peer_label="unconfined"
Apr 22 22:02:06 renatko-HP-Laptop-15-da0xxx kernel: [ 51.043641] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Apr 22 22:02:20 renatko-HP-Laptop-15-da0xxx kernel: [ 64.669566] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 22 22:02:20 renatko-HP-Laptop-15-da0xxx kernel: [ 64.669570] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 22 22:02:20 renatko-HP-Laptop-15-da0xxx kernel: [ 64.679034] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 22 22:02:20 renatko-HP-Laptop-15-da0xxx kernel: [ 64.679037] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 22 22:02:20 renatko-HP-Laptop-15-da0xxx kernel: [ 65.131543] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 22 22:02:20 renatko-HP-Laptop-15-da0xxx kernel: [ 65.131562] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 22 22:02:20 renatko-HP-Laptop-15-da0xxx kernel: [ 65.143299] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 22 22:02:20 renatko-HP-Laptop-15-da0xxx kernel: [ 65.143313] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 22 22:02:21 renatko-HP-Laptop-15-da0xxx kernel: [ 65.405495] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 22 22:02:21 renatko-HP-Laptop-15-da0xxx kernel: [ 65.405510] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 22 22:02:21 renatko-HP-Laptop-15-da0xxx kernel: [ 65.416655] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 22 22:02:21 renatko-HP-Laptop-15-da0xxx kernel: [ 65.416668] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 22 22:02:21 renatko-HP-Laptop-15-da0xxx kernel: [ 65.585398] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
Apr 22 22:02:21 renatko-HP-Laptop-15-da0xxx kernel: [ 65.585413] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 22 22:02:21 renatko-HP-Laptop-15-da0xxx kernel: [ 65.596396] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Apr 22 22:02:21 renatko-HP-Laptop-15-da0xxx kernel: [ 65.596421] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.766519] snd_hda_intel 0000:00:1f.3: couldn't bind with audio component
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.813880] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC236: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.813897] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.813905] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.813912] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.813916] snd_hda_codec_realtek hdaudioC0D0: inputs:
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.813921] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.813926] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.866462] snd_hda_codec_hdmi hdaudioC0D2: No i915 binding for Intel HDMI/DP codec
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.866853] hdaudio hdaudioC0D2: Unable to configure, disabling
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.867634] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx kernel: [ 66.867796] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx systemd-udevd[3009]: controlC0: Process '/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime restore 0' failed with exit code 99.
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx systemd[1127]: Reached target Sound Card.
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx systemd[1]: Starting Save/Restore Sound Card State...
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: Found hardware: "HDA-Intel" "Realtek ALC236" "HDA:10ec0236,103c84a6,00100002 HDA:8086280b,80860101,00100000" "0x103c" "0x84a6"
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: Hardware is initialized using a generic method
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #18 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #19 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #20 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #21 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #22 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #23 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #24 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #25 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #26 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #27 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #28 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #29 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #30 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #31 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #32 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #33 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #34 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #35 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #36 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #37 (No such file or directory)
Apr 22 22:02:22 renatko-HP-Laptop-15-da0xxx alsactl[3014]: /usr/sbin/alsactl: set_control:1339: failed to obtain info for control #38 (No such file or directory)
