το frostwire σε manjaro δεν τρεχει
HOSTNAME IS kostas-w251esqw270esq
Starting FrostWire... Java exec found in PATH. Verifying... Suitable java version found [java = 1.8.0_265] Configuring environment... Loading FrostWire: Error: A JNI error has occurred, please check your installation and try again Exception in thread "main" java.lang.UnsupportedClassVersionError: com/limegroup/gnutella/gui/Main has been compiled by a more recent version of the Java Runtime (class file version 55.0), this version of the Java Runtime only recognizes class file versions up to 52.0 at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:756) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142) at java.net.URLClassLoader.defineClass(URLClassLoader.java:468) at java.net.URLClassLoader.access$100(URLClassLoader.java:74) at java.net.URLClassLoader$1.run(URLClassLoader.java:369) at java.net.URLClassLoader$1.run(URLClassLoader.java:363) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:362) at java.lang.ClassLoader.loadClass(ClassLoader.java:418) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:352) at java.lang.ClassLoader.loadClass(ClassLoader.java:351) at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:495) ****************************************************************** Something went wrong with FrostWire. Maybe you're using the wrong version of Java? (FrostWire is tested against and works best with with Sun's JRE, Java 1.7+) The version of Java in your PATH is: openjdk version "1.8.0_265" OpenJDK Runtime Environment (build 1.8.0_265-b01) OpenJDK 64-Bit Server VM (build 25.265-b01, mixed mode)
