Παίδες εγκατέστησα το arch όλα καλά δόξα το θεό, έχω ένα προβληματάκι όμως . Το Bluetooth δεν λειτουργεί
‘Bus 003 Device 002: ID 03f0:171d HP, Inc Bluetooth 2.0 Interface [Broadcom BCM2045]’
καμιά βοήθεια από το arch wiki δεν έκανα τίποτα
Περίληψη
[tkor@tkorlinux ~]$ inxi -F
System:
Host: tkorlinux Kernel: 5.4.15-arch1-1 x86_64 bits: 64
Desktop: KDE Plasma 5.17.5 Distro: Arch Linux
Machine:
Type: Laptop System: Hewlett-Packard
product: HP Compaq 6730b (GB987EA#B1A) v: F.20 serial: <root required>
Mobo: Hewlett-Packard model: 30DD v: KBC Version 96.23
serial: <root required> BIOS: Hewlett-Packard v: 68PDD Ver. F.20
date: 12/07/2011
Battery:
ID-1: BAT0 charge: 0% condition: 56.6/56.6 Wh (100%)
CPU:
Topology: Dual Core model: Intel Core2 Duo P8400 bits: 64 type: MCP
L2 cache: 3072 KiB
Speed: 1605 MHz min/max: 800/2267 MHz Core speeds (MHz): 1: 1693 2: 1603
Graphics:
Device-1: Intel Mobile 4 Series Integrated Graphics driver: i915 v: kernel
Display: x11 server: X.Org 1.20.7 driver: intel unloaded: modesetting
tty: N/A
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express v: 2.1 Mesa 19.3.3
Audio:
Device-1: Intel 82801I HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.15-arch1-1
Network:
Device-1: Intel PRO/Wireless 5100 AGN [Shiloh] Network driver: iwlwifi
IF: wls1 state: up mac: 00:21:5d:19:01:8a
Device-2: Broadcom and subsidiaries NetLink BCM5787M Gigabit Ethernet PCI
Express
driver: tg3
IF: ens5 state: down mac: 00:22:64:51:a9:51
Drives:
Local Storage: total: 347.79 GiB used: 10.85 GiB (3.1%)
ID-1: /dev/sda vendor: Team model: T253LE120G size: 111.79 GiB
ID-2: /dev/sdb vendor: Intenso model: SSD Sata III size: 236.00 GiB
Partition:
ID-1: / size: 24.48 GiB used: 8.59 GiB (35.1%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 79.02 GiB used: 2.26 GiB (2.9%) fs: ext4 dev: /dev/sda3
ID-3: swap-1 size: 6.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
Sensors:
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 176 Uptime: 1m Memory: 3.75 GiB used: 975.4 MiB (25.4%)
Shell: bash inxi: 3.0.37
Πιπέριιιιιιι
Καταρχήν να περιγράφεις με περισσότερη σαφήνεια το πρόβλημα. Αν κατάλαβα σωστά είναι USB το bluetooth.
Για εγκατέστησε τα πακέτo
sudo pacman -S bluez bluez-utils
στη συνέχεια δες αν είναι ενεργοποιημένο το module του πυρήνα το btusb
lsmod | grep -i btusb
και τέλος ξεκίνα το service
sudo systemctl enable bluetooth.service
και δες αν διορθώνεται
lucinos
Φεβρουάριος 1, 2020, 6:51μμ
3
Ένα βασικό ερώτημα είναι αν έχεις windows και αν το bluetooth λειτουργεί εκεί.
Αυτό είναι λίγο βασικό γιατί πολλά λάπτοπ έχουν κλειδωμένο το bluetooth και ο μόνος τρόπος να ξεκλειδωθεί είναι από windows. Αν ξεκλειδωθεί τότε λειτουργεί και από λίνουξ.
όχι δεν είναι usb ενσωματωμένο είναι
lucinos:
και με manjaro και με mx linux δούλευε
lucinos
Φεβρουάριος 1, 2020, 6:53μμ
6
anon12951060:
δούλευε
οκ, τότε άκυρο αυτό που είπα. Δεν είναι κλειδωμένο.
Γενικά το Arch έχει αυτή τη μαγεία του φτιάξτο μόνος σου, οπότε στο 99.999999% των περιπτώσεων δε μιλάμε για πρόβλημα αλλά για μια λύση η οποία αναγράφεται ή στα Arch forums ή στο Arch Wiki.
Προσωπικά θα προτιμούσα πρώτα να πειραματιστείς λίγο με το wiki και τι μπορείς να κάνεις μόνος σου και μετά να άνοιγες το θέμα.
billniakas:
[tkor@tkorlinux ~]$ lsmod | grep -i btusb
btusb 65536 0
btrtl 24576 1 btusb
btbcm 16384 1 btusb
btintel 28672 1 btusb
bluetooth 671744 5 btrtl,btintel,btbcm,btusb
Τα υπόλοιπα που γράφω τα έκανες;
το έκανα ρε Βασίλη δεν καταλαβαίνω γιατί το κάνει ???
ναι τα έκανα όλα μόνο restart δεν έκανα
Με συγχωρείς τότε, το διάβασα λάθος το αρχικό σου ποστ.
Ωστόσο δεν μου απάντησες αν έκανες αυτά που σου έγραψα ως απάντηση και αν δούλεψαν.
Κάνε και ένα restart
Επίσης δώσε και ένα output της εντολής
systemctl status bluetooth.service
μετά το restart όλα οκ ευχαριστώ @ billniakas
αυτό δεν είχα κάνει
Έτσι για του λόγου το αληθές δεν αναφέρετε στο wiki
https://wiki.archlinux.org/index.php/Bluetooth
Installation
Install the bluez package, providing the Bluetooth protocol stack.
Install the bluez-utils package, providing the bluetoothctl
utility. Alternatively install bluez-utils-compat AUR to additionally have the deprecated BlueZ tools .
The generic Bluetooth driver is the btusb
Kernel module. Check whether that module is loaded. If it’s not, then load the module .
Start/enable bluetooth.service
συγνώμη δάσκαλε θα προσπαθήσω παραπάνω
Όλοι βρισκόμαστε εδώ για να μάθουμε από όλους. Δεν είναι κανείς μας δάσκαλος αλλά όλοι είμαστε μαθητές
lucinos
Φεβρουάριος 1, 2020, 7:16μμ
16
Εμένα μού αρέσει να το θέτω ότι στο λίνουξ δεν υπάρχουν powerusers, υπάρχουν μόνο αρχάριοι χάκερ :P
