Καλησπέρα παιδιά. Χρησιμοποιώ manjaro με Kde και δεν μπορώ να βρω τα bluetooth ακουστικά που έχω.
Σας παραθέτω κάποιες πληροφορίες
Output of systemctl status bluetooth.service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2020-04-06 15:20:33 EEST; 3min 13s ago
Docs: man:bluetoothd(8)
Main PID: 688 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 6911)
Memory: 2.4M
CGroup: /system.slice/bluetooth.service
└─688 /usr/lib/bluetooth/bluetoothd
Απρ 06 15:20:33 manjaro bluetoothd[688]: Bluetooth daemon 5.54
Απρ 06 15:20:33 manjaro systemd[1]: Started Bluetooth service.
Απρ 06 15:20:33 manjaro bluetoothd[688]: Starting SDP server
Απρ 06 15:20:33 manjaro bluetoothd[688]: Bluetooth management interface 1.14 initialized
Απρ 06 15:20:39 manjaro bluetoothd[688]: Endpoint registered: sender=:1.54 path=/MediaEndpoint/A2DPSink/sbc
Απρ 06 15:20:39 manjaro bluetoothd[688]: Endpoint registered: sender=:1.54 path=/MediaEndpoint/A2DPSource/sbc
Απρ 06 15:20:40 manjaro bluetoothd[688]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Απρ 06 15:20:40 manjaro bluetoothd[688]: RFCOMM server failed for :1.69/Profile/HSPHS/00001108-0000-1000-8000-00805F9B34FB: rfcomm_bind: Address already in use (98)
Απρ 06 15:20:40 manjaro bluetoothd[688]: Endpoint registered: sender=:1.69 path=/A2DP/SBC/Source/0
Απρ 06 15:20:40 manjaro bluetoothd[688]: Endpoint registered: sender=:1.69 path=/A2DP/SBC/Sink/1```
Output of bluetoothctl
bluetoothctl
bluetoothctl
Agent registered
[bluetooth]# power on
Changing power on succeeded
[bluetooth]# devices
[bluetooth]# scan on
Discovery started
[bluetooth]# agent on
Agent is already registered
[bluetooth]# agent
Missing on/off/capability argument
Βλέπω δύο error στο systemctl αλλά δεν ξέρω τι είναι
